I cut my first dovetails by hand... *LINK*
>Without a saw or chisel.
Want to know how?
Check out this link.
Stephen
Hand Cut Dovetails
Want to know how?
Stephen
Hand Cut Dovetails
Re: I cut my first dovetails by hand...
>And how did I make these dovetails, with the tools pictured; a cutting or slitting gauge and a knife. I dovetailed these two pieces of wood together in about 12 minutes, not knowing what I was doing. I used the cutting/slitting gauge to cut the cross grain and the knife to cut the rip and split out the waste.
Hi Stephen
Full marks for enginuity!
I am a little confused what you did, however. It reads to me that you used the knife as a combined saw and chisel, slicing and prying away the waste?
Can you explain more?
In the future I will pay a lot closer attention to how old drawers are put together. It is easy to see saw marks on the inside of drawer backs with half blind dovetails. Sometimes the inside kerfs go beyond the score line for thickness, in order to get more cut on the angle. Saw marks are sometimes visible as the craftsman went beyond the score line.
Thank you. On several occasions I have queried posts here and elsewhere that recommended the use of a mirror to monitor the back of a board being sawn for tails. It's the saw cuts on the front of the board that count. I am not fussed if I go over the line by a mm as the "gap" created is minute and will not be seen inside the drawer (I still try not to go over the backside line, but I refuse to get paranoid about it).
I think with a little practice, especially in softwoods or maybe thin hardwoods that it might be a time saving method.
I am most tempted to send you a couple of Jarrah boards to try this on. :) You may re-adjust your thoughts! :) heh .. heh.
>Derek,
"I am a little confused what you did, however. It reads to me that you used the knife as a combined saw and chisel, slicing and prying away the waste?
Can you explain more?"
I used the knife to get into the tight corners and to split off waste as the cutting gauge cut to depth. By removing the waste it allowed the blade of the gauge to get deeper.
"Thank you. On several occasions I have queried posts here and elsewhere that recommended the use of a mirror to monitor the back of a board being sawn for tails. It's the saw cuts on the front of the board that count. I am not fussed if I go over the line by a mm as the "gap" created is minute and will not be seen inside the drawer (I still try not to go over the backside line, but I refuse to get paranoid about it)."
Going past the line on the back of drawer fronts was done intentionally and sometimes quite far into the back side of the drawer front. I have seen this on a piece from the Chippendale shop in London, it wasn't on the 'money side' so the dovetails were rather crude if compared to modern fastidious work.
'I am most tempted to send you a couple of Jarrah boards to try this on. :) You may re-adjust your thoughts! :) heh .. heh. '
If you can determine that Jarrah was used in 1857 in the Territory of Utah, I will give it a try.
Stephen
I usually paint my dovetails on! Easy touchup too!
Alan DuBoff
Good one Alan! ROTFLMAO 8^)
Scott Burr in Ben Lomond, CA
Re: I usually paint my dovetails on! Easy touchup
Jim Toews - Walla Walla, WA------WebKitFormBoundar
>Don't laugh too quickly: I saw some "dovetail tape" printed with pins and tails to be applied to the edge of any butt-jointed corner. I'd like to believe they were intended as a gag item, but I fear they were a "serious" product for the manufacture of curb furniture. Sigh...
Cheers!
Jim
from your headline, I was picturing
>Stephen the karate master. Still not by hand, really...
Pretty cool, and makes sense - what are saws and chisels but refined knife edges?
