Another foolish vise story...when 24 is 28!
Alan DuBoff
>Rob,
Since we're on the April 1st 'thang, I couldn't help but tell you of another foolish vise story...it all starts casually while building my 'apffelMaker bench, a Holtzapffel with an Emmert clone for the end vise, using the Veritas twin-screw on the face. This is also a lesson in redesigning projects on the fly, in the sense of DON'T DO IT! *g*
I had planned for the vise to be 24", with the screw nuts flush with the end of the vise chop, patterned off the bench Schwarz built...but while putting the screw nuts on, I decided to move them out 2" on each side, so that the ends of the screw-nuts would extend, that's a nice touch on Chris's bench. After I completed this modification on the fly, I realized the screw-nuts would be 28", actually it turned out to be 28 1/8"...:-( (sounds of cursing)
Turns out I can't easily move the screw holes the 2" out on each side, since the bolts are there...drats (more sounds of cursing)
So, I had read that you could extend the twin-screw by adding more chain, and I ordered 12" of chain from McMaster-Carr (more foolishness to follow on that;-). It came a day or two later, like they always do fast shipping there, just like LV *wink*...and I look at the numbers in the install doc you provide, and whola, I see the there are numbers for links at 12" and at 16 1/8", so 4 1/8" was 20 links. Since I'm 4 1/8" wider that just seems like luck in calculating how many links I need, but I know I need 4" on top, and 4" on bottom pretty much.
After I start to get the link off, I realize you really need a chain breaker tool, which can be gotten at most local bike stores. The tool will be re-used by my son who mountain bikes and didn't have one, so no extreme loss. (even more sounds of cursing)
Finally, get start to assemble, and while measuring it seems I need to put an extra link, so I add 21 instead of 20. Get it all together and it works, but the chain is a bit loose for my taste, and the slack doesn't work as I would like, so I remind myself that everyone says the twin-screw is finicky to get assembled, even the instructions imply it. So I remove a link, since it seems that the wise thing to do, but I then find out you can't just remove one link, you have a remove a section...and then the chain was too small...but you also provide a half link, so I get that, add it on...of course that takes time to figure the pin is keyed...(more cursing at myself for being a dolt!;-)
Then I try to make the chain fit, but can't get it just about an RCH, but it wouldn't go...so I loosened up the screw plates, put the chain on by removing the chain pin with plastic barrel you provide...then extend them back out as far as they would go to take up the slack, and then putting the bottom pin in where it was makes the chain just about right, there is no slack. This works how I want, no slack when you tighten/loosen the screws.
Oh, the other foolish thing about this is that when I opened the cover kit, there was extra chain in there already...(no cursing, but laughing at myself...;-).
It's now lined with leather on the chop and together...28 1/8" center-to-center. I feel foolish over this, but I'm a happy fool in the end...*wink*
Yeah, that twin-screw is a piece of cake to install...*rotflmao*
And this doesn't end without having to make some type of custom cover for the chain...;-)
NOTE to self: The instructions said to follow them closely, that this was not a project to deviate too much on...or something like that...:-/
