How to heat 11-foot strips for bending?
Dave Mount
>A while back some folks here helped me find resources on how to make snowshoes. Well, this past weekend the neighbor lad and I cut down a 7" ash tree with a clear, straight bole, took a 12 foot log from it and split it up. The bad news was that this particular tree had a minor case of spiral grain, which gave about 60 degrees of rotation over the length of the log. That made shaping the strips a little interesting, but we ended up with 6 13/16" by 13/16" by 12-foot long 60 degree spirals. Although it was a pain to shave following a spiral, I'm not really worried about it as we can bend it back out when we apply the strip to the form; in fact, by each holding an end and twisting, we could straighten it without heating just with hand pressure. Kind of comical to cut down a tree and then yield nothing but 6 skinny strips of wood (and a huge pile of shavings). I buried them in a snowbank for safekeeping until we bend them.
Anyway, to the point. I need to figure out how to heat these pieces for bending. My steambox is only 4 feet long; I could make a bigger one, but I don't really have a way to generate the kind of steam that I think would be needed to heat an 11' plus long box. My thought is to use a hot water bath instead. The cross section of the pieces is relatively small to begin with, and the only part of the piece that has to take a severe bend is the toe, which is shaved down to only 5/16" thick. I made some wooden pitchforks a while back and was able to bend 1.25" rounds by just ladling boiling water over them for a few minutes.
My current thinking is to piece together a 12-foot section of 4" PVC pipe (might have to use something better than sewer and drain), cap one end, and fill it with boiling water (would take about 7.5 gallons). I thought I might surround the pipe with hay bales and loose hay (these I have) to help slow heat loss.
Any thoughts, suggestions?
Best,
Dave
