Wide dado method
David Cockey
>Here's the method I used today to cut a 4" wide, 1/2" deep dado in two 1 1/4" wide douglas fir timbers. The dados needed to be the same width and depth, and the bottoms neded to be flat and relatively smooth. Tools used were a carcass saw, chisel, shoulder plane and bench plane.
1) Mark the depth of the dados on both sides of both timbers.
2) Clamp the timbers together with the faces aligned and mark the width of the dados.
3) Chisel along the knife marks for a 1st class saw cut as Chris Schwarz teaches.
4) Saw the sides of the dados. Also saw kerfs between the sides of the dado. These kerfs should be slighty further apart than the width of the chisel used to rough in the dado.
5) Rough out the dado close to the depth marks. Work from both sides towards the center.
And now the clever part (at least for me).
6) With the shoulder plane against on side wall of the dado start planing at one face of and go 80% to 90% of the way towards the other face. Be careful not to go below the depth mark. This creates a shoulder plane width ramp across the dado. Repeat against the other side wall of the dado.
7) Turn the timbers around and do the same with the shoulder plane starting at the other face. Be careful not to let the blade go past the other face. That way there is no danger of cutting below the intended depth on that face.
8) Level the shoulder plane grooves between the faces by starting the plane with the blade just inside one face and planing to just inside the other face.
9) Use the bench plane in a similar manner to bring the wood between the faces down to the inteneded depth. Level and smooth the surface.
It sounds complicated but is actually simple and quick in practice. A lot faster and more accurate than I can chisel. I've used it several times now for lap type joints.
