Blade retrofit 4 Old style LV Wheel Marking Gauge?
Dominic Greco in Richboro PA
>Hi gang,
While I was looking through the latest LV catalog I noticed the Veritas Wheel Marking Gauge. I have an older version of this tool and have really have gotten to love this tool while working on my latest project.
One of the things I noticed about the older version marking gauge is that the sharpened steel wheel is fastened onto the graduated cylinder by a pan head screw. The newer versions utilize a countersunk flat head screw. This allows you to use the marking gauge as a "depth gauge" as well. I sure could have used this little feature while routing grooves today!
I noticed in the catalog (and on the web site) it states, "Standard wheel gauges purchased prior to Sept. 2004 require a different style of replacement wheel cutter. Please order the wheel below"
Now, I'd really love to be able to use my trusty old LV marking gauge to transfer depth setting from piece to piece. But I'd rather not have to buy a whole new tool! I was wondering if any of you know if the new style blades come with a screw, and will work on my old style marking gauge so that I will allow me to take advantage of this feature. I'd even settle for knowing the size screw that the new gauges use so I could try to make it work myself.
Hey Rob Lee, are you out there?
See ya around,
Dominic
Re: Blade retrofit 4 Old style LV Wheel Marking Gauge?
>Hi Dom
I have an older LV wheel gauge (pre-mortice for the blade ... which I subsequently added).
Don't let Rob Lee see this ... shhhh.... but all the fittings from the Tite-Mark are interchangeable with the LV I have (I have the TM as well). So, if you can't retrofit the blade and screw from the LV, you could do so using the TM version.
Thanks Derek!
>Derek,
Thanks for the heads up! I really do enjoy using this marking gauge. Once I'm able to make this retrofit, it will get used even more so.
See ya around,
Dominic
Rob Lee
>Geez Dom...it's the weekend! :)
Will check into this for you tomorrow....our main system is off-line right now (security upgrades)...
Cheers -
Rob
Hi Rob!
>Rob,
You wrote:
"Geez Dom...it's the weekend! :) Will check into this for you tomorrow....our main system is off-line right now (security upgrades)..."
Aw man! Now I feel bad for making you work during your time off! :>)
Seriously, thanks for replying. I'm not in a super duper hurry. I'm about to order another couple of those 1/4" LV Lg router plane blades so I can make a 3/16" spear point and bull nose. I was just curious and wanted to know if I should include the replacement wheel marking blades in my next Lee Valley order.
See ya around,
Dominic
