What is this?
What is this?
What is this?
>I bought a Stanley #45 about 10 years ago. In the box was this piece of shaped wood. It did not look original. I had no idea what it was for. For years I have taken it out the box with the intension of throwing it away, then tossed it back in again..
Any ideas?
Re: What is this?
I'll bet . . .
steve mackay
>Don't know but I'll bet it was something very specific for a project or task. I'd be interested to know what it was. Looks like a lot of thought and effort went into it.
Re: What is this?
Re: What is this?
>Looks like several pieces of wood I have, just too good a scrape to throw away. I have a piece of lignum vitae, stair stepped on one end as I cut off small pieces for projects.
Stephen
Re: What is this?
Story stick?
John Veerkamp
>Looks like a story stick for a specific project.
Re: What is this?
Re: Gauge block?
Dave Mount
>Hi Derek--
It has the look of a some kind of gauge block used for quick set-ups to commonly used dimensions. I have some small blocks I use for common depth/height settings (1/4", 3/8", 1/2", etc.) I don't know if the dimensions of that block have any application to a 45 set-up. . .
Best,
Dave
Re: What is this?
This kind of mystery
>is why I have taken to writing the purpose of the little blocks of wood I use as this and that, in Magic Marker, directly on the block.
I agree that it's likely a gauge block. Of course, in the absence of your knowledge of what it is, it's just a chunk of wood.
Re: What is this?
Re: What is this?
wilbur
>Maybe it's an insert for a box so that when you put your #45 and its attachments away, the compartments made by this piece of wood keep them from rattling around in the box.
I know there's an actual term for what I'm trying to describe, but the only thing that comes to mind is "French cleat", and I know it's not that.
Re: What is this?
Maybe
Wiley Horne -- So. Calif.
>the pattern for the preliminary waste cuts for a run of moulding. Use that block to mark the end grain of the work, and also to do the filletster and plough set-up. Save the block in case he ever wants/needs to do it again.
Pure guess.
Wiley
Re: What is this?
Re: What is this?
Marv....... Northern California Lake Co.
>Derek,
This has got to be one of the most interesting threads to be posted in many many weeks. *smirk*
Allow me to ponder...
I see a hole on the top that doesn't exit. I see one corner cut to an angle. I see some scuffing on the lower surface. It's purpose was to swivel on a dowel to allow the bottom surface to either hold something up or down.
Other than that, it's just a piece of wood waiting to be made into something equally mysterious.
It's too late now, but you could have given it a name and entered it in the hand tool contest. Looks like a winner to me....
Marv
Re: What is this?
Wandering OT
>when I briefly did sheet metal work for a living, we scribed a lot of lines at set (short) distances from the edge of the stock - 1/2", 3/4", and so on - for various standard bends. The journeyman I was working under taught me to take a rectangular piece of stainless steel scrap and make a scriber, which just has points cut out of the sides. I'd best jot an explanation of the tool's purpose on it, to avoid these speculations when my sons are cleaning out my shop (I hope many years from now).
Re: What is this?
Re: Wandering OT
Todd O. Cronkhite Maine Native, Presently Away
>Has definitely got to be some type of guage block.
If you really want to find out whatit is, use my technique and throw it away. Works everytime! }:~[
Re: What is this?
Why it's a...
Scott Burr in Ben Lomond CA
>piece of wood 8^)
I'm guessing some sort of gauge block as well. I like Todds idea as well. That always works for me...8^(
