Plough plane question
wilbur
>[I would have said plow plane, except that my plane comes from England.]
I have a Record 044 plough plane that I really tried using for the first time this week. I have a question about the fence and the depth stop.
I'd like to make a groove that is pretty close to the edge of the board. It's close enough to the edge of the board that if I use the fence to mark the distance of the groove to the edge, the depth stop can't be used. If I lower the depth stop, I have to move the fence out of the way to set it at the depth that I want.
What I did was to use the fence to get the groove started, then removed the fence and dropped the depth stop, and proceeded to plow (sorry, plough) the groove to the depth that I wanted, using the sides of the groove to keep the plane in line. The problem I see with this method is that I would need to start all the grooves first, then remove the fence, then plough (got it right that time) the grooves to final depth. If I forget to start a groove, it would take some futzing around to get the fence set back just right.
I think that there must be a better way to do this. How do you deal with this situation?
