Ah Ha! What about this idea?
Alan DuBoff
>Stephen,
I had to include "Ah Ha", it just felt like one of those moments when I realized something.
I keep grabbing that handle I was rasping on yesterday, and it just feels good in my hand. Aesthetically, there are some minor things I will change, but I like how it feels.
On both sides of the handle, the wood is still flat, about 3/4" in width. Both the rear of the handle, and the front of the handle which are held in the hand are still a bit rough from the rasp, and in fact have marks which have been left from the rasp which flow along the contour.
SHAMELESS PLUG for TFWW: I used Joel's saw maker's rasps, I love those...and I also use the riflers, I wish he made rasps in all the various rifler shapes, in the size of the saw maker's rasps (I guess that's a plug and a plea;-)
I like the feel of the grooves left from the rasp...
So, this brought me to the Ah Ha moment...you were recently mentioning the toothing blade on the surface of the old furniture, and that would be good...in fact I was thinking what if, not a plane, but a smaller type chiseling handle with a toothing blade, of oh, only 4 or 5 points was used to effectively create a pattern on the handle which would be left as a checkering in effect? I think I might like something like that. I don't want large checkering, that is for certain, and I would like to experiment with grooves and other patterns that didn't completely cross, because that would seem to remove even more wood and possibly result is a smoothed out checkering, from use. By leaving more material, the chance of that could possibly be minimized. As an example, a toothing blade pattern of straight grooves opposed to diamond shaped points left from checkering.
OTOH, some type of larger beading on the rear of the handle might be desireable, depending on how one layered the contour. I hope my mind is not being too abstract, but I like the idea of having some texture on the handle, some texture does feel good to me.
Someone mentioned that guns require accuracy and the checkering helps, but I look at my joinery work as being similar...I not only intend much of the time, but HOPE that I can get a cut from joinery saws which that does not require any additional work. Nothing worse that having to use a chisel because the saw cut was not accurate enough...BTDT...:-/ (maybe that's why a chisel is one of my favorite friends;-)
Not to digress, I think some type of tool that does allow one to scrape a pattern on handles for texture, could be useful, for me anyway...*LOL*
Oh, and I wanted to add something on finish, because in the past I have used BLO with wax, and it works ok for me. I like the feel of the wood. But the one problem is the dirt factor. Without something protective over the BLO, it seems to attract dust/dirt/grime after the wax wears away...which it usually does in use...at least for my grimy sweaty hands...
