liquid hide glue question
McKay Sleight
>Are you able to hammer the cold liquid hide glue in the same way that you do the hot? Thanks in advance.
McKay Sleight
Re: liquid hide glue question
Tony - Memphis
>Are you talking about hammer veneering? If so, I don' think so. The cold hide glue takes quite a while to set vs. the hot hide glue which sets rather quickly.
I have used cold or liquid hide glue (Franklin brand) for veneer, but I pressed it for a few hours. Not my first choice for veneering, but it was on the bench at the time! Worked fine though.
Tony
Adam Cherubini
>I never tried it because I think (and was told) it wouldn't work. You really rely on a quick grab. In fact, in hammer veneering, it seems you rely on working at the ragged edge of the glue's working time. You are pushing it down, squeegy-ing out, and reactivating dry spots or bubbles.
I think its good to keep fresh liquid hide glue as an additive for hot hide glue. Otherwise, I don't like working with it.
Adam
Of Course you can
>Liquid hide glue works just fine for hammering big sheets. If you use hot hide glue on big sheets the work and space must be quite warm to get to it before it gels.
Go ahead and use cold hide glue it works great, no matter what size project you have.
Stephen
Coupla questions....
Wiley Horne -- So. Calif.
>Stephen,
I was glad to see MacKay's question, because I'm going to need to place some fairly large veneer, and thick (3/32"), without using hot glue.
The difficulty I see having is based on the slow tack of the cold glue, and the thickness of the veneer. I'm thinking Old Brown Glue.
Questions: When you use cold glue for veneer, of course there is glue on the downside, but what about the upside? Do you apply glue on the upside also, to prevent curl, or do you just wet it with water? Do you use cauls to keep everything pressed down flat? Do you use tape at the seams to pull the sheets together?
Any clues on the details would be appreciated.
Thanks in advance,
Wiley
Re: Coupla questions....
>Wiley,
If I had my Hide Glue book finished all of the answers are in there.
I think OBG is the best liquid hide glue on the market, nothing wrong with Titebond/Franklin either.
I use veneer tape to hold pieces together where joints are involved.
For hammer veneering I will glue both sides and use the glue on top as a lubricant, don't need as much on the top. Water also works well sprayed on to prevent curling, as veneer will do that when glue is applied.
I use flat and shaped cauls for specific purposes, zinc faced if possible and warmed prior to using.
I hope that answers your questions.
Stephen
>Thank you very much, Stephen. Yes that does answer. I'll be on the lookout for your book also. Please let us know when it becomes available.
Wiley
But...
Dean Lapinel
>Make sure that's it's within the recommended "user date"
of ...I think 6 months?
I use the real stuff but add my (free) urea at a lower percentage of 3-4% for just a slight delay in set time. I think Franklin has the equivalent of 10-12% additive that I don't think is necessary. Fresh Franklin is fine for many uses but I wouldn't use it on my violins.
FWW gave Franklin a thumbs up on strength but in real life use, I find the glue breaks the bond more easily (in violin making). I know this is empiric and personal testing but when hot glue isn't a big deal then you don't take chances.
Re: And
>I have made the liquid stuff myself with nitric acid, there are dozens of recipes for making hide glue that is liquid at room temperature. All of these do have a shelf life and the expiration date printed on the bottles are good lines. It is twelve months from manufacture. Making the stuff is a bit of a bother as I use too much to do this, but you should do it at least once, you may find it rewarding.
Knowing from personal experience that Franklin/Titebond will only sell me liquid hide glue in 5 gallon barrels when they manufacturer it or I have to wait until their next batch.
Now I have been doing some experimenting and have been using liquid hide glue that is well over 12 months PAST its expiration date and still passes the freshness test, strength test and the practical test.
I would recommend using the stuff before the expiration date And if the glue will pass the proper tests I think you can make exceptions. There are also considerations of how this glue was stored, freezing in the winter may very well have prolonged the expiration date.
Further research is underway, but it looks like keeping you glue in the refrigerator or freezer will prolong its shelf life. Troublesome when you want to use it, I had to dig it out of the bucket with a putty knife, now that is an interesting process.
Stephen
David Wheeler
>Adam,
I guess I never considered mixing liquid hide glue to my hot glue to extend setup time. Not a bad idea.
Re: And
Tony - Memphis
>I've always wondered about the date. I have some that is way beyond the date and it still seems to work, but I'm always a bit hesitant to use it. What is the test(s)? What is the failure mode? I end up throwing away a half bottle almost every time - hate to waste it, or anything for that matter.
Thanks,
Tony
Re: And
>Tony,
The freshness test is taking some liquid hide glue between you index finger and thumb and touch them together repeatedly. If it forms legging, cottoning or webbing (different words, same thing), it is fresh.
If it doesn't then it is no good for gluing but still suitable for crackle finishes. And if you don't do crackle finishes, dilute it with water and put it in your garden, lots of nitrogen.
Failure test is the 'failure of adhesive bond' as opposed to 'failure of substrate. If it takes wood with it, failure of substrate it is good. If the bond breaks clean with no wood on either side, it is failure of adhesive bond. In one the wood breaks and in the other the glue breaks.
Stephen
Re: And &
>Tony,
If you are throwing away half a bottle, try pouring out half of a new bottle and putting it in the freezer. When the first is gone, thaw out the frozen glue and use it.
Stephen
Thanks!
Tony - Memphis
