? on tuning a side bead iron
Dave Mount
>I made a 1/4" side bead plane (pics will come in good time) and I'm working on getting it cutting well. I've never even handled a vintage side bead so I'm working from pictures found on the net and don't have a working model to learn from. I've opened the mouth roughly 1/32". In use, it clears the main shaving from the quirk as it starts to sink, but I get a buildup of fine, fibrous material over the deepest part of the profile (these test cuts are in paper birch, which I find easy to plane in general, with the exception of frequent grain reversals). When the plane sinks deep enough that the bead part of the profile should start cutting, I find that the fibrous material deposited earlier in the process just kind of mats over the rounded part of the profile and it won't cut. I have to remove the iron to clear the material, reset the iron, then it cuts OK, but it's a pain. Any suggestions? How wide should the mouth be? I can easily float it open a little more, but I'm hesitant to open the mouth more if the problem might be elsewhere. How critical is the mouth opening on a small bead like this?
Thanks for any advice,
Dave
