Slick rehab questions
Paul Erickson
>I am in the process of rehabbing this 2" slick. It has obviously been abused for some time. I have a few of questions.
1 - I am in the process of peening the socket, and I wonder if I should be concerned about work hardening the top of the socket? Should I consider annealing the top part of the socket, or just proceed trying to restore as much of the original shape as possible?
2 - What is the proper name for this type of slick? Bent neck?
3 - How long should the handle be?
4 - Should the handle be straight, or should I attempt to curve it just above the socket so that the majority of handle runs parallel with the back of the blade?
Thanks in advance.
cheers, Paul
Re: Slick rehab questions
Re: Slick rehab questions pic 2
Paul Erickson
Re: Slick rehab questions pic 3
Paul Erickson
Not Slick Bent Chisel
Todd Hughes
>Not a slick but a bent chisel.Maybe bent on purpose to better get into an area or maybe bent as it was used as a pry bar[my guess] You could leave it as it is now , an abused tool, or try to bend it back. Should bend back but with things like this always a certain risk of it breaking. I would use the jaws of a vise to bend it back some wich always seems safer then just putting a pipe over it and pushing.
... I would just cut the end of the socket off looks like you have plenty left.
...Handle originaly was just a regular chisel handle with a leather bumper probably,maybe around 4- 6 inch long, looks like a bevel edge chisel which would be kind of unusual to see with an iron driving hoop.
Never see a real slick with a cutting edge as small as 2 inch or made like this chisel .....Todd
Jesper, Denmark
Re: Not Slick Bent Chisel
Jesper, Denmark
>Are you sure it is not a cranked in-cannel gouge?
Patternmakers tool for taking very fine shavings.
Todd Hughes
>Maybe I am missing somthing but sure doesn't look like a gouge to me but rather a chisel with a straight cutting edge.
...Never saw or heard of a crank neck socket chisel always crank neck tang chisels....Todd
Offset socket chisel? *LINK*
Paul Erickson
>Thanks for the replies. Looks like it might be an "offset socket chisel"
http://www.henrytaylortools.co.uk/wwchisel.html
cheers, Paul
Henry Taylor Woodworking Chisels
What ever it is...
>Wrap a wet rag around the blade and heat the mushroom up to cherry red and reshape it on a fine cone mandrel or socket drift. A small diameter round bar to act as an anvil on the inside of the socket, then pound the swelling away.
You will have to heat it several times, but you can do it with a hand tourch. It doesn't always work, but I have redone a few. It still requires a bit of grinding as the edge is usually fairly ragged.
Stephen
Function vs. design
>What is the difference between a slick and a very large chisel? I have what I always thought was a slick, that I (and my son in recent days) have used as a slick. Now Todd tells me it was just a big chisel. What's the difference between a slick and just a wide chisel? Woodcraft lists two slicks, 2-3/8" and 3-3/8" (granted, Woodcraft is no longer quite an authority on this stuff).
And here I thought I was being so slick.
Also.....
Wiley Horne -- So. Calif.
>Paul,
Just my take on things....A paring chisel with hand clearance (like the one you're showing!) is a very useful tool.
Maybe someone with some old chisel maker's catalogs can let you know whether they can find any that were offered with that sort of angle on the socket.
But even if it was used as a lever and bent to its present shape, I would give some thought to leaving it in the 'bent' condition, and using it similar to a cranked paring chisel than a striking timber chisel. It looks to be very useful as it is. Especially if it is given a longish handle, maybe 12" give or take. If it turns out to have a little too much hand clearance, you could make a small adjustment, but I'd think two or three times about trying to straighten it out.
2 cents.
Wiley
Slick Willy, You are!
tek-Brunswick, Ohio
What is a "slick"...
Bob Hackett
>A slick was used to do what a plane usually did only in very tight quarters where the knob,tote,lever cap,etc would not fit.
Lately you see every chisel that`s robustly made and over 1/2" in width called a "slick",just like all those wood jointers are "block planes" and every woodie that`s not a "block plane" is a "moulding plane" and some are evidently both.Most of these "slicks" are actually framing chisels and came hooped as they were meant to be driven by a mallet.A slick is a paring chisel only and NEVER hammered on by anyone who knows what he`s about.
There may be exceptions but all the slicks I`ve seen,used or heard of shared these traits;2 1/2" or wider,socket offset so handle doesn`t interfere when used flat,slight rocker(as in non-flat)in length so you can bring it up out of the cut and a curved cutting edge(about like a jack plane) to make it easier to steer.
That being said,I`ve also turned more than one 2" or less paring chisel into a "mini-slick" for those who needed them in thier work.I`ve also put a slick type handle on a large in cannel gouge so a fellow sculpting softwood could waste away wood in tight areas.
As to the length of the handle,it depends on your reach.Make it long enough so it`s comfortable to use with the knob or pad in the pocket of your shoulder and your guide hand on the socket.Slicks are also used with the handle tucked into the armpit so keep this in mind too.
Hope this helps.
Mainely,Bob
