My stack of wood project (pics included)
wilbur
>So here's my entry to our woodworking club's "Stack of Wood" contest. It's a benchtop tool rack for my commonly used chisels, saws, and hammers.
If you were on the weekly chat last week, you'll recall me griping about our woodworking club's "Stack of Wood" contest. The Stack of Wood contest is something our club does every year. One of the members has a woodworking business, and he puts together a stack of wood, primarily from cutoffs from his business. He donates the wood, contestants pay $10 per stack, and the club gets the money.
This is the first time I entered the contest, since I'm still a beginner in many ways. This was a bad move on my part. This year, the stack of wood seemed to come from a flooring job. The wood was primarily South American species from flooring stock. So the stack was made of long skinny and/or thin pieces of very hard wood with extreme amounts of cross grain, which made working with it really difficult. My neighbor said that he burned out two bandsaw blades and a set of planer blades working with this stuff.
Since this was a rack for my hand tools, I wanted to do this project as much by hand as possible. Other than initial jointing and planing of the South American maple by machine, I can say that this was otherwise completely made with hand tools.
The first thing I did was to try to plane the various pieces of wood. I found that I only had four pieces of wood out of the stack that I thought I could deal with. I don't remember the actual species names, but they were the South American equivalents of maple and walnut. The rest were jatoba and African mahoghany, and I passed on trying to use those. The South American walnut was pretty easy to use, if you paid attention to the grain direction. However, there were only two 6" long skinny pieces in the stack. The South American maple was easier to work with than the rest of the wood, but not by much.
The two legs of the base were joined with double 1/4" (actually 6mm) mortise and tenons. I wish i had taken a picture of that joint before I glued it up -- I was pretty proud of that one. The riser piece was joined to the base with a mortise and tenon joint as well.
Here's a detail of the leg. I chamfered almost all the corners of the pieces of the tool rack. I like how all the chamfers come together at a point.
I decided to try a sliding dovetail to join the crossbar to the riser. This was partly because I was using this project to try out new techniques, and partly because I was tired of making mortise and tenon joints. This is the crappiest sliding dovetail you'll ever see. I was getting all types of tearout when trying to make the male part of this joint.
Here's a detail shot of the crosspiece that holds the tools. This initially was just going to be a rack to hold my saws to get them off the thing that serves as my workbench, but I found that the crosspiece was long enough that I could fit my other frequently used hand tools on it as well.
You can see where I inlaid a strip of the South American walnut. I used a Japanese plow plane to cut the slot for the inlay, and also to make the recess that the tools can sit in. I cut out slots in the crosspiece to hold the hand tools I seem to be using most often. For the chisels, I used a brace and a Forstner bit to make a round hole for the chisel, and then cut out an access slot in front. That's when I learned why the bargain $20 for a set of 7 Forstner bits are so inexpensive. Time to place an order with Lee Valley. Hopefully you can see the chamfering I did on this part as well.
The inlay was a bit of a disaster. I didn't pay attention to grain direction when I first inlaid the South american walnut strips. As I said before, this wood was nice to work with -- unless you wind up planing across the grain. Because I didn't pay attention to the grain direction when gluing the strips in, this is what I wound up with. The tearout was so bad that I had to completely dig out the inlay and start all over with this part.
I decided not to use any finish. Despite the tearout issues I was having, the surfaces that planed well had a smooth enough surface that I decided to leave them be.
Hope you all like it. It was fun using this as an opportunity to try joints that I hadn't made before. I also learned all sorts of lessons about grain direction and planning for that when building a piece. I also got lots of practice sawing to a line, sharpening, and tuning up my Japanese planes.
