Best way of unclogging a diamond stone?
wilbur
>I (finally!) picked up a coarse DMT diamond stone last weekend, and have been putting it to good use. I have a question about the best way to clean the diamond stone after a lot of use. The instructions on the package say to use a non-petroleum based abrasive cleaner and a scrub brush.
Which is all well and good, but what "non-petroleum based abrasive cleaner" do you all use? The only one I can think of is Comet.
Also, is a brass brush a good or bad option for a scrub brush? I was thinking that the brass brush might be good as I imagine most of the stuff down in between the diamonds are going to be metal particles.
I also can't believe I haven't gotten one of these sooner.
Re: Best way of unclogging a diamond stone?
Mineral, Animal & Vegetable
>well mix lard and wood ash and you get soap and that covers all the bases. All you need is a good surfactant.
An old toothbrush will work as well to clean 'stones'.
Stephen, not using any modern terms, well maybe one.
ThomD
>It's a good question. Ajax is a cleanser that was designed for cleaning metal off metal for the aircraft industry or some such, and it comes out less soapy that some. With my stones it didn't seem as though cleaning would help, but maybe I should. I use my stones wet.
TMStock
>Cameo has a mild bleaching action that might help, but dish soap/hot water works OK.
Pam Niedermayer - Austin, TX
>For a brush you can use a simple fingernail brush from your local drug store.
Pam
David Charlesworth
>A plastic eraser sometimes works well for finer stones.
am I missing something?
Bill Tindall, E.TN
>I have been using diamond stones for some years now and never cleaned one. How does one know when cleaning is needed?
I suspect the reason DMT says to avoid petroleum based lubricants and cleaners is so that the plastic parts are not softened.
I use the all metal-diamond stones from Japan Woodworker. I have used them with a variety of lubricants and my favorite is diluted water based coolant from a machine shop. The tools slide nicely with this material. I suspect soapy water might do well too.
While on the topic, our club did demos at a show this weekend. Phil and I did sharpening. A neighboring booth's chair maker gave us a Stanley plane iron to do during the demo. It had been honed many times and there were a multitude of bevels to choose from. Phil hollow ground the bevel just shy of 30 degrees as requested by the owner, at 3600 rpm but with a very soft bond 7" wheel (see Articles for wheel description) right to the edge, with no burning. I followed with about 5 strokes on a fine diamond fixed abrasive and about 10 strokes using 1 micron loose diamond on cast iron. The back needed a bit of touch-up so I worked it on the 1 micron and got most of it polished. Total elapsed time about 2 minutes. Lookers-on were amazed.
Examination with a 10X lens, something I do unfailingly, revealed a small section of wire edge that had not been removed. A few more strokes on the 1 micron and the edge was perfect across its width. In testing, the iron smoothly clipped off the tops of finger prints, a much more demanding test than wrist hair. The later is a parlor trick. Examination with a lens is my primary quality control technique.
Cool. Thanks.
What do you have on hand?
tek-Brunswick, Ohio
>I've used paste metal cleaner, comet, waterless handcleaner with pumice, pumice powder and dish detergent all scrubbed with an old tooth brush, then rinsed with water. All have worked well. My routine is diamond hone, then ceramic home, and last a strop with green compound or flex cut yellow compound. The edges I get work for me. I can shave with them and more importantly the edges will cut wood cleanly.
