What kind of bits do I need?
Rob Hix - King George, VA
>Hey all,
Thanks for all of the helpful advice I have been getting over here. I am mostly a power tool woodworker, but I am about to delve into the realm of hand tools and making chairs and stools. One reason I am going for hand tools is the rustic look left by the tool marks. Another plus is that I can pack up my chair making tools and equipment and take them places with me.
That being said. I have come up with another couple of questions, and will probably have many more. This time it is about bits for my bit brace. The first question is what is the difference between spoon bits and regular auger bits? Second question is, which ones do I really want for chair making?
Thanks again for the input,
Rob Hix
Re: What kind of bits do I need?
Sharp ones!
>Glad to see you are giving up your evil ways and joining the quiet side.
Choose the bits that are appropriate for the chairs and stools you are making. Spoon Bits (sharpened on the end only) if you are making 18th century furniture and Cook's Twist Augers if you are making nineteenth century stuff. Jennings and Gedge are acceptable.
Learn to sharpen the bits properly and they will work well. If you choose twist augers with lead screws choose the proper threads, coarse for softwood and fine threads for hardwoods, there is also a medium and some were made with spur points (no threads). I like threaded augers as you can count the revolutions for depth, so many turns, so deep.
Stephen
ThomD
>I like spoon bits.They are easy to start and stear, and leave a good hole without any overtravel or punch through.
I wouldn't call hand tool marks rustic compared to, say, power tool marks. Perhaps you are thinking of rustic chair making, which often uses through mortises, in which case Forstner like bits sold by Lee Valley to compliment their tenon cutters, are a good deal.
Darrell in Oakville
Darrell in Oakville
>If I was buying spoon bits over again I would just get the 3/8(#6) size. The most difficult holes I have ever bored were on sack-back bows. It's a hole drilled at an oblique angle to a round bent piece of wood. Easy with the spoon bit. The rest of the holes are just holes, for the most part.
A friend of mine received a set of Lee Valley spoon bits for Xmas, and he dropped by on Saturday to we could bore some holes and compare my Emhof bits to his LV bits. Apart from the shavings produced, the bits worked and handled the same, IMHO. We'll see how well those LV bits stand up to (ab)use after Scott finishes a few chairs.
You might also look at getting a set of center bits. They are very old-school, and the marks they leave in the bottoms of the holes (be they round holes, or housings roughed out with a brace & bit) are more um, "rustic" for your purposes.
Darrell
Wood Hoarder, Blade Sharpener, and Occasional Tool User
rarebear
>Spoons are very easy to start on a angle or change directions in the begining and hole size better..
Brace bits are harder to start at an angle and dont cut as clean a hole..
Center Bits
>Work great for starting angled shallow holes. I have one with a very long pivot and it will start at very steep angles.
One disadvantage of center bits is that the are only good for shallow holes. Once you get below the paddle the bit can drift.
Stephen
Cook or Gedge Pattern
>will start at an angle and leave a cleaner hole that other twist augers. The upward curl of the leading edge cutters make a clean entry hole and smooth walls.
Stephen
Re: Cook or Gedge Pattern
Greg B�tit, Vergennes VT
>I've been looking for some of those ever since I found out that Curtis Buchanan uses them for chairmaking. He got his at garage sales. I've been checking eBay off and on with no luck.
greg
Little help?
Bob Hackett
>What sizes are you looking for?
Maybe with alittle help you can fill out your kit(and we will know where to go to borrow them).
Mainely,Bob
Re: Little help?
>Hi Bob,
I'm a little embarassed, I realize now that I should have made a post in the "Looking for Something" forum a long time ago.
I'm looking mostly for Cook/Gedge pattern bits from 5/16" - 5/8", with the 3/8" and 5/8" sizes being the most desirable.
Thank you,
greg
