Green Wood Question...
Rob Hix - King George, VA
>Hey all,
I am posting this on the hand tools forum since I feel like this group is the most likely to work with green wood.
I have some log sections out of a maple tree that some friends cut down recently. It is green wood and still in log form. I am planning on using it for some foot stool legs. I am unsure yet whether I will totally build the stool with hand tools or whether I will use the lathe. At any rate, I am planning on splitting the legs and stretchers for the stools out of the log here as soon as I can get my hands on a froe.
My question is, how should I treat the leg and stretcher blanks until I am ready to turn them (which will probably be several months)?
Thanks for the help on this, it is much appreciated,
Rob Hix
Re: Green Wood Question...
Re: Green Wood answers
Dave Mount
>Hi Rob--
I don't treat the ends of rivings, I just leave them an inch or two longer than final length and trim off any end checking. If you want to treat them, wax, latex paint, or a product called Anchor Seal are the standard treatments.
I'm not sure if you were wanting to prevent end checking or actually keep the wood green. Maple stains easily if the surface is not allowed to dry, so wrapping it in plastic or sealing the whole thing will likely result in staining and/or spalting. Only way to keep it green and unstained that I know of is to freeze the wood until you are ready to work it. I do that with rivings for chair back splats -- I freeze them while the rest of the chair parts dry and the frame is assembled.
You don't need a froe to split your wood. The primary splitting is done with wedges. I move to a single bit axe once I'm down in size a little bit (hit with a wooden club, not a steel hammer of course). I do have a froe, but that's only used for the last bit of riving down into really small pieces, and even at that, you can generally get away with using the axe all the way down. The only thing a froe gives you is a little better means to steer a split that isn't going well, but if the stuff splits well at all, it's not necessary. In my opinion it's a pretty narrow range in grain quality that is too quirky to do with an axe but is still salvageable with a froe. Remember to always split pieces roughly in half and things will usually split true if the stock is straight grained.
My $0.02,
Dave
Greg B�tit Crown Point NY
>Maple doesn't keep well as a log with the bark still on. There are bugs and fungi lurking out there.The smaller the pieces are split the less checking you will have. The sooner you turn it after the tree is down, the better.
If you plan on waiting a few months before your turn it, split it to turning blank size and cover the ends with shellac or other suitable sealer.
If I'm not going to work chair legs from a green maple log right away, I split and turn the split pieces to a cylinder 1/4" larger in diameter than the chair legs, then I coat the ends. It doesn't take much time (green maple turns like butter), and I know what I have. Many a split piece I've counted on being made into a leg has turned out to be not quite enough material to make the full diameter of the leg all the way around.
greg
James Watriss
>Advice I was given was to wait until late summer to split green wood, as it's warmer, and more humid, and therefore the wood isn't as prone to rapid moisture exchange as it would be in bone dry weather. Failing that, after you break it down, sticker the pile and throw a blanket over it all, to keep the air surrounding the wood nice and moist, to allow the wood to season in a slower and more controlled way.
>Thanks for the info guys. I think I will try a few in the freezer (the wife wanted one in the shop (garage), so I might as well get some use out of the space she took up. I think I will also try turning a few down to just oversize. I might as well see which I like better. I will need to do something with the wet stuff while I am waiting for the stool stretchers to dry. I am going to try to get that done in a small wooden box with a couple of light bulbs inside.
I am beginning to like the prospect of working with green wood. It looks like for chairs it is as good or better than anything else I could use, and with all of the residential growth around here, I should easily be able to get plenty of logs.
Once again, thanks. I will try to remember to let you all know how things turn out (pun intended).
Rob Hix
ThomD
>Freezing might dry it out, sublimation. You may want to do a good deal of the turning wet, it sure goes faster and will help the drying out. Also if you realize you need to reduce a bit by more spliting or even draw knifing it is still easy to work. If you have the option, rough turn right away to cylinders, coat the ends with white glue. Leave over length as mentioned. Split more than you need. I say borrow a log spliter for that length.
Re: Freezing green wood
Dave Mount
>Hi Thom--
I haven't had any problem at all with drying via sublimation storing red oak chair parts (longest storage = 9 months). However, I do put the wood in plastic and store it in a non-self defrosting chest freezer (as opposed to a kitchen freezer that defrosts and has high airflow).
Best,
Dave
ThomD
>That makes sense, and I can see doing it for specimin but for chair wood, I'd feel like the Anal Retentive Chef. I might be missing something though, since I tend to end up with too much wood rather than just the right stuff.
