Rubberized abrasives for sharpening
Dave Mount
>In his hollows and rounds video, Larry Williams mentions using rubberized abrasive cones for sharpening curved irons, and it strikes me that they might also be very good for gouges. There was also a recent message on the noisy side about using them for polishing. I did some looking on the web, and it appears that Cratex is the "Kleenex" equivalent in the rubberized abrasive world.
I was wondering if anyone here has experience using them, what you power them with, how fast you spin them, where you get them, what grits you use, any tips on using them, etc.
I've used sandpaper on dowels, and Bill Tindall gave me a tip about embedding diamond past in aluminum or brass rods. But a cone seems like a great shape for dealing with a wide variety of profiles and radii.
Best,
Dave
Re: Rubberized abrasives for sharpening
Neal in San Jose
>I posted on the noisy side about using rubberized abrasives in my Dremel tool for polishing augers for a hollow chisel mortiser. I've not used them much for other things, but it appears that they could do a good job. The problem for me is that it is easy to remove more metal than I mean to. That isn't a problem on the side of a hollow chisel auger, but you could change the profile of a molding plane blade in the blink of an eye. The set I bought has two colors of abrasives, and I suppose that relates to different grits, but for the life of me, I can't see any difference in the surface they leave. I've been very happy sharpening gouges and molding plane blades with Arkansas and water stone slips, so I haven't been motivated to try the rubberized abrasives. With a light touch, I suppose it would be successful.
Something that just occured to me is that I just got a variable speed Dremel at the office holiday gift exchange, so maybe if I turned the speed down, the abrasives would be more controlable. When I get a spare shop minute, I'll try it and report back.
ThomD
>Lee Valley used to sell them, they were expensive then, and not too many grits were available. I would have thought they would not stand up to modern options very well. I don't remember what speed they were run at but they were run on normal grinders which are 3600 or 1800. Part of the idea was they didn't overheat, which also seems like a hack concern.
I did have some smaller rounds that I neighbour gave me, but I never really liked things that mounted in drill motors. They can glaze over.
Doug Reynolds in Seattle
>I have used them for gunsmithing to install oversized beavertail grip safeties and the like in Colt 45 semi-autos and their clones and, to make other modifications to gun frames. I used either the Dremel or Foredom for power. They are available in a number of grits sizes and shapes so, I never worried about taking off too much at a time.
