Head scratcher
Head scratcher
Head scratcher
Edward in Vancouver
>Don't know if this OT or not, but does deal with hand tools, in particular edge tools.
In my "other life" I'm a Chef, and it was yesterday that I was labourously scraping a 5 kg slab of chocolate to get shavings to decorate a cake, that the lighbulb went off. Why not use a plane or shave to scrape the chocolate? Currently I hold a sturdy chef's knife at an almost verticle position and draw the knife towards me, scraping off chocolate in the process.
I currently have a LV BU jack and smoother, a old post 60's Stanley #5, and a cheapo #51 clone India made shave--none of them do a satisfactory job of shaving chocolate. That being said, if I use the shave on the edge of the chocoalte slab, I do get some shavings, but even though I have a solid maple baker's table at work, it has no vice or holding devices to hold the slab on edge while I shave it....
Any suggestions?
Re: Head scratcher
Inshave or Scorp
>should work, also a handled box plane, the type used to remove lables from packing boxes. Also there is a brass pull shave that bowl and spoon makers use, should also work.
You probably need something like a heavy radius blade on a scrub plane.
Be careful when you lick your tools when you are done, the blade is sharp.
Stephen
Re: Head scratcher
Jack Guzman from Maine
Drawknife?
Re: Head scratcher
If you're using a chef's knife as a scraper,
>wouldn't a scraper plane be the next one to try? I'm picturing a Stanley No. 80 cabinet scraper.
Re: Head scratcher
I've used a...
Scott Burr in wet windy & cold Ben Lomond, CA
>Low angle spoke shave with good results. Contary to what Stephen says, don't lick the tool when your done, causes rust ya know.
Re: Head scratcher
Re: Head scratcher
Pam Niedermayer - Austin, TX
>I shave 1/2 oz of unsweetened chocolate every day for breakfast (turns out that a little chocolate on top of bananas on top of granola, cranberries, and raisins is delicious and very healthy). So far I've used smallish stiff knives, which work just fine; but I've also been thinking there must be another way, too many shavings shoot across the counter if I forget to brace the knife toe on the counter. The way my Bakers shaves makes me think a spokeshave probably wouldn't work all that well, you'd get big chunks of spelch. Interesting problem.
Pam
Re: Head scratcher
Re: Head scratcher
Edward in Vancouver
>Thanks for the replies. I do have a LV cabinet scraper that I'll try out, and what others said about a scrub plane makes sense too. Might grind an aggresive radius on the cheap #5's iron.
However there is one problem I haven't taken into account: Friction. If I get too energetic with the plane, friction from the sole starts melting the slab. Well, I guess I could rub the sole of the tool with cocoa butter and flip over the slab every so often....
Re: Head scratcher
Chilled chocolate...
David Barnett - SW Florida
>...and a warm potato peeler (HOT water on blade, quickly wipe dry or soft spreader flame from a plumber's torch) produce nice curly wood-like shavings. You may have to try (or make) a few peelers to get the right aperture and heat-holding combination. If you practice, you can get shavings with a smooth shiny finish rather than rough edges and cracks.
Re: Head scratcher
Re: Chilled chocolate...
>I just knew you'd have a good answer for this, David. Do you have to clean off the peeler when you reheat?
Pam
Re: Head scratcher
Warmed Chocolate & Cryo Blade
Re: Head scratcher
Re: Head scratcher
Steve Nelson
>What about a cheese slicer?
Re: Head scratcher
But wait! There's more!
>The hot (not boiling) water method works better for higher fat chocolates whereas the dry method is better for hard darks. Some wipe (actually 'swipe') the hot peeler on a damp sponge or cloth before and after reheating over the soot-free flame. Too hot a knife will ruin the temper of the chocolate (scorch the cocoa, break the oils, and adversely affect the fragile vanilla and other flavor components). You gots to get your rhythm on.
Berti (Italy) makes a chocolate knife/hammer set for chopping and chipping at just under $400 USD (ouch!). Belgian chocolatiers used a 'chocolat' knife for shaving blocks into rolls which could be petaled into roses and florets. These typically were offset both at the handle and by slitting and stepping the rear half of the blade, the lower blade section lifting the chocolate strip into the elevated set-back blade step, producing an even ribbon (ribbons can be poured, as well). The lower blade (bevel on the bottom) was considerably thicker. Some of these were double handled. Nowadays, a machine does all the work, whether cranked or motorized.
In Bogota I've seen fondues charged with chocolate chipped with wide (maybe 1 1 1/4" to 1 1/2", thick and short wood chisels. These seemed almost square at the ends. No bevel. These were also used (unheated) to pull a curl.
Re: Head scratcher
Milk/Dark, this is going to get ugly
Re: Head scratcher
Jim in Burlington Ont.
Pull scraper
>http://www.leevalley.com/wood/page.aspx?c=1&cat=1,310&p=45784
I'd try it as is first but probably a slightly rounded blade would work better. Those plastic handled paint scrapers with the articulated head would probably work as well.
Re: Head scratcher
Too much milk is udder adulteration
Re: Head scratcher
Re: Head scratcher
Walt in Tenn.
>How about a scraper plane. You aren't using the knife as an angled slicer so typical plane blade angles shouldn't work well either. Or putting one of LV's scraper frogs in a handplane.
As for friction, they use parafin in making chocolate so parafin on the sole of the plane? I use parafin on my plane soles when I am making final passes on wood.
Walt
Re: Head scratcher
Re: Head scratcher
Edward in Vancouver
>Thanks for all the replies, I'll be trying out the cabinet scraper tomorrow. To see what I do for a living, go to www.schokoladecafe.com
Re: Head scratcher
Ice shaver plane
Todd Hughes
>I bet one of those old ice shaver planes they used to use to make ice shavings would work good for you.They even have a compartment to hold the shavings.....Todd
Re: Head scratcher
Oh, the envy!
>I suppose I could double up on both insulins and risk a couple of those Italian nougats and tiles.
"The only way to conquer temptation is to yield to it." - Oscar Wilde
Re: Head scratcher
Re: Head scratcher
Dave Anderson NH
>I don't see why a very light touch with a very sharp drawknife working around the corners of the block wouldn't work. There's no throat to jam up like with a plane or a shave.
Re: Head scratcher
Very interesting, some weird knives. Thanks.
Re: Head scratcher
looks luscious
>Ooh, hide the credit card, don't let me go there.... :)
Pam
Re: Head scratcher
Re: Head scratcher...link
Louis-in-TO
>Edward, I think you're looking for something like this:
http://www.cooksite.com/IBS/SimpleCat/product/ASP/product-id/833145.html
Re: Head scratcher
Mandolin
