Saw Jointer Files
Saw Jointer Files
Saw Jointer Files
David Miller from Iowa
>Anyone know a source for tangless files to use in saw jointers? Yes, I know tanged files work (except in the Disston hinge type ones), but the karma is better with a tangless file.
Conversely, can one cut a file?
Thanks, David
Re: Saw Jointer Files
Todd O. Cronkhite Maine Native, Presently Away
>can one cut a file?
Yeah, you can cut on with a hacksaw, but it'll take quite awhile and wears out hack blades real quick. It's much easier to break one by taking a hacksaw and scoring it where you want it cut, then put it in a vise right at the score line and snap it off.
I will admit that I have done only one this way. It was about an inch wide and it took some serious tugging to break it, but it snapped off clean and straight. I also wrapped it up in a cloth just in case it shattered or something.
I'd imagine doing a file small enough to fit into your jointer would snap off much easier.
T.O.
Todd Hughes
>Just take a file put it in you vise with the lentgh you want below the jaws. Tap it with a hammer,[ain't goin to take much] and it will snap right off at the top of the jaws breaking along the line of the teeth. You can grind it straight across if you are the type that likes to do things like that.....Guess theres harder ways to get one but doubt if there are many easier ones....Todd
Like Todd O's way but different...
Scott Burr in wet windy & cold Ben Lomond, CA
>This requires killing a few 'lectrons. Use a Dermel tool with a cutoff wheel to score the cut lines then snap file at the score lines.
