Dovetail layout tricks?
Tony - Memphis
>I've been cutting my first dovetails recently. I'm building a lowboy and I decided to try and cut the half blinds by hand. The instructor that taught the lowboy class (Phil Lowe) was smart enough to use pine as the secondary wood. It is forgiving enough to be smashed into shape without splitting!
Anyway, couple of things I'm wondering. Any tricks to laying out the pins/tails? I did it via measuring and that's fine, but I know there are some tricks like what Rob Cossman does with dividers out there.
Also, When I am cutting the tails and the waste side is on the other side of the blade, I have a hard time following the line cause I can't see it. Any thoughts there?
My dovetails are looking decent for a rookie I think. Better than I thought they would. I feel like half blinds are more work, but also more forgiving since less joining surfaces are visible. My sawing is getting better. I can cut reasonably close to the line and tweak it for a decent fit. Still a few gaps here and there, but not terrible. I've only cut a couple of through dovetails and those came out ok. Hey, a few thousand more and I'll be a good beginner!
I'll try and take some pics.
Thanks,
Tony
