Tool Refinishing
David Miller from Iowa
>Picked up a decent Stanley #66 hand beader Type 1 - painted bright green.
I'm not going to re-jappan it, so what is the next best choice - spray enamel?
Thanks
Tool Refinishing
Thanks
Re: Tool Refinishing
Todd Hughes
>I had a friend get one befor that was painted blue. He used a mild paint stripper on it and carefully removed to blue paint to find that underneath it was about 90% of the original jappaning...somthing to try.
...If you want to paint it imagine spray paint would work ...Maybe what the guy used when he painted it green .....Todd
Jack Guzman from Maine
>Why not leave it green? I don't think you'll mind so much when you're using it.If the color really offends you,just strip it and coat it with a light coat of oil.If you gotta have a color,rustoleum works fine.---Jack
Kunz or John Deere green?
Scott Burr in Ben Lomond CA
>Marv might want to buy it from you;^).
My favorite choice here is black epoxy paint brushed or sprayed.
>Hi David
I sometimes find really rusty tools. After citric acid, they end up bare cast iron. What I may do is use a deburring wheel on the metal, remove the tarnish, and what is left is a clean surface. I then wax it for protection.
Here is a #66 I have:
Of course you may want to try my fence modification (article in archives). Makes a world of difference..
The other plane I have just done like this is a #46. This is in good condition - actually very good condition - but started out very rusty. Now I am even thinking about re-nickeling. It is just a user, but may be worth the effort because it is such a nice plane (and it came with all the blades). What do the others here think?
Thanks
>to all the posters.
Derek - I think I will make a fence as you suggest. I'll probably just use the original fence as the starter, should be pretty easy.
Mike Hamilton
>Derek,
Two questions:
How did you handle the pinned handle and citric acid bath?
Can you explain a 'deburring' wheel?
Regards,
Mike Hamilton
Plainfield, IN
>Hi Mike
A deburring wheel is used ... to deburr ... remove burrs after grinding. They come in different grits and are capable of polishing steel to a mirror.
Here is one (picture taken off eBay):
The handle on the #46 was taped up tightly with waterproof tape. I did not want to damage the wood by forcing out the pins.
