floor jack
McKay
>I searched for plans for a floor jack with no luck. Does anyone have a link or plans for a jack that can be used to support long boards extending from the face vice? Thanks in advance.
floor jack
McKay
Re: floor jack
ThomD
>There are plans in the various bench books. Franz Klaus has one in his oft reproduced bench. It was in the original bench book by Taunton press and several magazine articles. It consists of a crossed foot for the base, and a vertical @ 2x2 that is notched on one side. There is a metal bracket that hangs off the notches and support the jaw for your board. If you saw a picture you would hardly need plans. An even simple model if you have a tail vise is nothing more than a 2x2 with dowel holes up one side, that fits in the jaws of your vise, then the peg is moved to the appropriate height. You can do the same kind of thing with a bar clamp.
I just use my stool.
Re: floor jack
>Here is a drawing of a traditional 'dummy' used to support the ends of boards. It adjusts similar (except upside down) to adjustable candle holders or adjustments on wooden bar clamps.
The iron staple catches in the opposite notches and hold the face piece at different heights. The notches are cut to match the peg holes on your bench.
Hope this helps.
Stephen
