Wooden molding planes
TiO
>These two home-made planes were bought at an estate sale. There were many sets of different sizes, so the maker had made quite a few. They seem well made but were used only little, if at all.
In use, I find they don't work as I would expect. Could it be the design/manufacture? Or more likely, is it the user?
The squarish heel is uncomforatable in my hand. Even at full retraction, the 1/4" thick blades still cut and cut too aggressively for me. Shavings clog the central hole and do not eject from the plane body.
I've been able to cut a bead along the edge of a scrap board but it's a lot coarser cut than I would have expected. Trying to cut a hollow is difficult but mainly because it's hard to keep in a straight line. Should a fence arrangement be used when trying to cut the hollows?
Any ideas?
Terry in Ottawa
Re: Wooden molding planes
wilbur
>Dealing with the squarish heel is easy. Round off the corner to whatever shape fits your hand.
As far as the aggressive cut, when you say, "Even at full retraction, the 1/4" thick blades still cut," I'm interpreting that as the blades really aren't fully retracted. If they were, they wouldn't be able to cut anything.
Have you tried starting with the blade set so that there is no cutting action at all, and bumping them forward until you do get a cut?
The other thing I had to learn when using wooden planes is that it's very easy to tap too hard when trying to set the position of the blade. When setting the blade of a wooden plane, you really only need to tap the blade lightly.
Warren in Lancaster, PA
>This guy was no great planemaker, so you needn't worry about making alterations for improvement. There is a slot for the shoulders of the iron that is just above the escapement hole. If this slot were made deeper (higher up) the iron could be retracted to the point that it does not cut. You could use a file or a chisel for this work.
For making a cove molding, first cut a small rabbet on the edge of the board and run your round plane in this guide to get started easily.
Mike Schwing from Md.
>The first thing that comes to mind other than that which wilbur has offered is: "is the iron sharp?" Are you sure you know what sharp really is? Most handplane usage issues, from people who don't use them regularly, seem to have to do with sharpening, or lack thereof. Some of the results you describe could be due to a dull iron. What is your sharpening method?
And yes, use a fence.
Darylee
>I only got a router last year. I've been using mortising and hand planes for...30+ years now as I started with my grandads as a kid.
Sharp blade...a must...razor sharp and no burrs.
Hopefully they have quality steel.
I've only used what are now antique factory made planes. Someting looks wierd to me with these...I can't put my finger on it.. It has to do with the relationship of the tensioning hole and the wedge/stell alignment. It may be allowing the steel to move?
Anyway. once sharp put the steel in. make sure it's flat with the bottom most surface of the plane. I was taught to use a piece of glass not steel to set this. then gently tap the steel so it slides just a bit to take a bite..they are nothong like the steel 'stanley' block and floor planes.
Brad in Ottawa
>I agree with Warren, the irons should be able to retract further into the plane. A little file work will take care of that in a second.
Brad
