How would you do this?
Jack Guzman from Maine
>I need to build a panel door for under a stairway. Unfortunately the door has to have a corner left out to fit the slope. I have no idea how to join the cut out corner. I'm sure I'll come up with something,maybe mitered and splined? Anybody done this? Any ideas? The panels have to float. The sketch isn't to scale.It's just to illustrate what I'm talking about. The door is approximately 2'x4'.thanks ---Jack
Re: How would you do this?
Ray Binnicker
>Wouldn't mortise and tenon work? I've done a couple angled mortise and tenon projects and they worked pretty well.
Ray Binnicker
Stuart Hough
>Might not look super pretty, but how about bridle joints?
I was gonna suggest that
Denis Ch�nard, Orl�ans, Ont.
M&T
Bill Tindall, E.TN
>I looks to be easy to make the joint a mortise and tenon. I would make the tenon perpendicular to the mitered end of the angled piece and a straight mortise into the rails top and side. You will be making plenty M&T's for the rest of the framing anyway.
I hadn't thought of that.
>That's why I asked here. Sounds like it may be a winner.I'll be puttng the door together first thing tomorrow morning.Pretty shmitty-the door's getting painted.It'll look great when it's done.---Thanks for the idea---Jack
Warren in Lancaster, PA
>I think the strongest configuration for your door would be straight tenons on each end of the slanted piece, going into slanted mortices. These would make the strongest joints.
Here is another idea that would be a little stronger yet. Make the top rail and the diagonal piece out of one piece of wood, with the grain going in an intermediate direction (about 15 degrees from horizontal). You might need a piece about 11 inches wide. On the top edge you could cut off the corners to get your shape to fit the opening, on the bottom edge you could make a nice arc.
>Jack,
Is it going to be Painted or natural? That is not a very large door and will probably not be used that much, I think? I have seen some examples in historic buildings that were constructed to look like what you want however the construction is simpler.
The Door is made of t&g boards and the thin strips, rails and styles are just nailed and glued onto the boards, painted and its done.
Or you can do the traditional method of floating panels held in rails and styles with the suggested 'bridle' joint. I am assuming that the bridle joint is an open slip or open mortice and tenon joint?
Stephen
THANKS
>This is a closet hidden under a stairway. The intended purpose is for storage.It will get very little use and is being painted to match the trim in the hallway.The client wants the door to match the rest of the doors through this part of the house. They are all 6 panel doors.I'm still not sure what I'm going to do but I got some good ideas here.I'm building it in the morning and I'll figure it out with my morning coffee.
Thanks for all the ideas.---Jack
Darylee
>ditto
do a scale layout first, that will help your brain from bursting
Darylee
>I'm not used to this board...mortise and tennon .. do a layout first
Floating tenons
>I'd try to do something like this. Make your angled rail long enough to put tongues on the ends that fit into the panel grooves in the stile and top rails. Once you have that all done and fitting nicely, rout mortises as shown for loose tenons.
My 2�,
You beat me to it Ellis...
Scott Burr in somewhat warn Ben Lomond, CA
>I was thinking loose tennons also.
make that 3 of us
Mike Schwing from Md.
different design
Dean Lapinel
>I would not use that short diagonal...I would extend that diagonal all the way and use a haunch for torsional strength. Would look better as well.
Re: different design
ThomD
>I agree the diagonal should be full span, and the other parts fit into it.
There was a door like that in my Grans' house, and I have to say I completely forget what it looked like.
How I did it....
>Ellis' suggestion of loose tenons sounded feasable and simple enough to do except for cutting the mortises.That part of it just seemed like it would be too fussy for me.The bridle joints struck me immediately.It sounded right for the application and not too difficult to execute,so that's what I did.I did however make the angled piece the long way,cutting the tenons out of the rail and stile.I thought this looked alot better than the other way.
Thanks for all suggestions.---jack
Re: How I did it....
Todd O. Cronkhite Maine Native, Presently Away
>Looks like a nice pieces of work Jack. I have to agree with you in that I liked the bridle joint suggestion the best myself. Is that all hand tool work?
Make sure to show us the finished and installed door.
T.O.
Installed door
>Todd,
I used both hand and power tools to create the door.I used a tenoning jig to remove the center/mortise of the bridle joint but fit the tenon ends(of the bridle joints)with hand tools.What are these parts called? The other mortises are all hand cut.---Jack
