A restored Stanley #45 Combo Plane
Dominic Greco in Richboro PA
>Hello Everyone,
I just got done working on restoring a rusty old #45 that I purchased off of Ebay back in October of 2007. Other than being dirty as hell and having surface rust, it wasn't in too bad a shape.
I just disassembled the entire plane then clean each part with a brash wire wheel brush. Each piece got a coat of 3 in 1 oil and was allowed to sit over night. Tonight I wiped off the pieces and reassembled the plane.
After that I started on the blades. At the same time I got the #45 I got a bunch of them from Ebay. I concentrated on the straight bits. The reeding bits will have to wait. These needed a good cleaning as well. After that I reground the bevel, making sure I got a nice edge that was perpendicular to the sides. BTW, the thin 1/8" blade at far right of the group is one of Jim Reed's. Many of the shavings in the photo were made using that blade.
Since it was getting late, I just honed the 1/4" blade and installed it in the plane. I tested it out with a piece of scrap maple. As you can see, it worked out OK. But I still need some practice using this bad boy.
Thanks for viewing!
See ya around,
Dominic
