Sheppach sharpener
Sheppach sharpener
Sheppach sharpener
>I picked up one of these for $100. I have a question for those who have something similar, Tormek, Jet, Grizzly. When I sharpen my smoothing plane blades I have always pushed down on the corners to the a slight curve to the blade. I've only started to sharpen one blade on this thing and it doesn't feel like it rocks any. I guess I'll be able to tell more when I get to finish the process I just thought I would rough it out to find out if there was any deep pitting in the rust on this blade. I'm restoring an older wooden smoothing plane and just started on the blade.
Anyway my question is can you get a slight curve to the edges using this or should I use it to rough out the edge and then go back to my scary sharp method for finishing the blade.
Re: Sheppach sharpener
Dan Donaldson
>Not familiar with that one, but I have a Tormek and I mainly use it for the roughing shape of the blade and then finish on stones.
>Hi John
I know the Scheppach quite well, although I have the Tormek 2006.
These machines are best considered grinders and are best at creating a primary bevel. One moves from there to sharpening media, such as waterstones, which is where I create a camber. The camber should not be attempted on the basic blade grinding fixture as it is not designed to be canted. There is available (from Tormek) a flat rest that may be added. This can be used to grind a camber.
Thanks- that's kind of what I thought.
