Re: Digital camera recommendations--OT
wilbur
>Hi Wiley,
Sure does make sense.
If you are looking for a camera with the controls you want, especially if you want flash compensation, you're going to be looking at a digital SLR or "SLR-like" camera. A digital "SLR-like" camera is usually a little smaller than a SLR, but does not have interchangeable lenses, and usually has less in the way of easily accessible controls. If you're used to using a Nikon 6006, a digital SLR will be very similar as far as handling goes.
For example, the "SLR-like" Panasonic Lumix DMC-FZ18 has flash compensation, but requires you to hit buttons on the back of the camera and look at a display screen to adjust it. The Nikon D40X, which is a full fledged DSLR, has you push a button by the lens mount and spin a dial to adjust this, while displaying the info in the viewfinder, as well as the display screen. This may sound cumbersome, but trust me -- it's easier to do this on the Nikon D40x.
By the way, I don't think that the Lumix is a bad camera -- it just won't be as easy to do what you want your camera to do.
As far as low light shooting goes, a digital SLR will give you much more flexibility in finding a portrait lens that's fast enough for your needs. Again, looking at the Lumix I mentioned before, the lens is a 28-504 (!) mm F2.8-4.2 zoom. Maybe this will be fast enough in portrait shooting for you, maybe not, but that's the only option for a lens on this camera. This lens is actually made by Leica, so it's not a bad lens -- it's just your only option.
Nikon DSLRs are able to use some older Nikon mount lenses, so if you have a lens for your 6006 that you like, you may be able to use it on a Nikon DSLR, although it may be with some limitations.
Things you don't need to concern yourself with are super high amounts of megapixels (unnecessary) and high ISO settings (I think that settings above ISO 200 is uniformly too noisy regardless of camera at this point in time, and ISO 200 isn't good in many cases, but I'm pretty picky about this).
My guess is that if you know enough about cameras to be able to use flash compensation effectively for fill in, you'll be happier with a DSLR. However, a $400 budget will only get you to the bottom of the DSLR segment these days. In your case, my suggestion is to see if you can stretch your budget a little, and look at the Nikon D40 or D40x, since they may work with your current lenses. Canon also makes very good DSLRs, if you don't mind switching brands. If you look at the "SLR-like" cameras, make sure that they have flash compensation, since not all of them do, and that using it isn't too much of a pain.
And even though I mentioned this already, be sure to look around on www.dpreview.com
Hope that helps!
