panel angle?
Bill Tindall, E.TN
>what is a typical angle for raising the panel on a frame and panel door (the bevel angle if one might it that).
panel angle?
Bill Tindall, E.TN
Re: panel angle?
>Bill,
I think it depends on the type of panel and how thick it is. I have seen raised panel on thin boards with wide bevels that are just a few degrees.
I have also seen 'raised' panels that have a flat field (that fits in the groove) then the bevel was steeper than 45 degrees to the raised field.
If the back is flat or has a bevel, rabbit or feather on back side will effect the angle on the front. Also the thickness of the panel plays into the geometery of the raised panel.
In historic times many of the raised panels were put on the inside and the outside that showed was a flat panel. Planing a panel nice and flat was considered the premium, raised panels not so much.
What is the application?
Stephen
Re: panel angle?
Paul Kierstead
I was under the impression that was only for Shaker furniture with their prohibition on decoration. Was this done for non-shaker furniture as well?
Re: panel angle?
>Paul,
You Wrote:
'I was under the impression that was only for Shaker furniture with their prohibition on decoration. Was this done for non-shaker furniture as well? '
Continental, English and their influences together with the popular Empire style furniture went for flat panels. This is not a universal truth, raised panels were placed on the outside. I think people thought about things differently 150 years ago.
Stephen
Re: panel angle?
>Most of the panels we use typically the reveal between the stile & rail and the raise on the panel is about 1-1/4". My own personal opinion is that a panel should have a small flat around the outside perimeter to fit into the frame. If you are using hand tools to raise the panel and are not limited to the cut your router bit or shaper cutter makes you can easily change the angle of the raise to get different effects on the panel.
another question on making the "flat" part
Bill Tindall, E.TN
>Indeed the flat part to fit the groove sounds like the proper approach. How does one achieve this flat? I don't do enough panels to justify a shaper or router cutter so these will be hand done by some means. The project is doors from 5/4 lumber.
Re: another question on making the "flat" part
>Bill,
The traditional method is with a moving fillister plane or a rabbit plane with a fence. It is possible to do it with a clamped on straight edge, if the plane does not have a fence.
Use a marking or cutting gauge to layout the rebates to gauge your planing or cutting.
The plane should also have a nicker blade to score cross grain on the ends. If it does not then the line should be scored prior to planing to prevent tear out. You can also use a crosscut saw and straight edge to cut the ends that are cross grain.
Some old panel raising planes would have this flat as part of its profile. Without the flat part, a method like the one above or similar is used to cut the flat first.
Stephen
