angled or splayed dovetails
chichi
>I paid for a booklet that describes the process for splayed dovetails and I am a little confused by the directions. Can someone direct me to an article or explain the process.In the instructions I have, the tails are laid out relative to the entral axi of the board and not by referencing from the angled edge. The lines across end grain are not perpendicular but at the angle the ends were cut. Does this sound right?
Thanks,
Bob
Re: angled or splayed dovetails
>"Tage Frid Teaches Woodworking" book about "Joinery:Tools and Techniques" has a good section on splayed dovetails and I found it an interesting book to read. I think you can find past threads on splayed dovetails as well. On your project are both sides of the box angled or is one angled and one vertical?
Warren in Lancaster, PA
>I used to make what we called cutlery trays for wholesale when I was first in business, so I've done a lot of this. I used to sell them for $12 plus materials. It really got the attention of other woodworkers. But as you have discovered from your booklet it is not easy to describe. I agree with the statements you quote from your booklet, but I can see they are difficult.
Here is the easy answer. Plane a bevel on the bottom surface of each board that is equal to the splay angle. Then all other angles are worked off this bottom reference surface. For example when you "square" the endgrain edges to the face of the boards, the blade of your square should be tilted parallel to the beveled bottom, not perpendicular to the face. This bottom surface is what your booklet refers to as axis.
It would help visualize if you had an example in front of you. Perhaps you can get a friend to make one corner joint for you.
chichi
>Thanks for the help. Both boards are cut at an angle according to the instructions. It is the difference in the angle of the tail lines that has me most confused. I will try putting a bevel on the bottom edge and work off that.
Any articles available online?
Bob
>Chichi, if you usually cut your dovetails at 8 degrees and your splay angle is 10 degrees, then for your dovetail markings you can use 10+8= 18 degrees and 10-8=2 degrees marked from the end. This way both tailcuts are roughly 8 degrees from the grain direction (which is parallel to the bottom). If you mark the angles just 8 degrees working off the endgrain both ways, then one side of the dovetail has rather short grain and is weak. Also remember that when you extend your dovetail layout lines across the endgrain, they should be parallel to the bottom. Use the bottom of the tail board to set your bevel gauge. Use the bottom of the pin board to set bevel gauge for the pin extensions.
