Re: hand plane assembly - HELP! #2
Wiley Horne -- So. Calif.
>Hi Rick,
Stopping back by Woodcraft would make sense, cause they should have done a few shavings with you in the first place.
On your questions:
1- Is the bevel of the iron up or down (as you look at it in the plane?
The bevel is down. The chipbreaker is on top of it, which means that the bevel side of the blade is sitting on the frog.
2- How far is the chipbreaker from the edge of the iron?
This is not critical (at this stage), but say 1/16" is fine. What is important is that the little tang on the end of the depth adjust assembly is passing through the blade slot, and is engaging the little hole in the chipbreaker.
3- How tight is the chip breaker to the iron? Not critical at this stage--it can be screwed tight with no harm. Much can be said about adjusting chip breakers, but right now we're still trying to get the plane to work.
4- Currently I have the Depth adjustment wheel turned all the way tight(end) (counter clock wise)
This may be an issue. There's no rule about turning the depth adjust wheel all the way counterclockwise. You set the depth adjust wheel so that the little metal hook or tang passes through the blade and engages a hole in the chipbreaker. Turn the depth adjust wheel to a place where that tang will engage the chipbreaker hole. There's no preset location--by inspection, you just look where the tang is relative to the chipbreaker hole, and turn the wheel until it engages nicely.
You then adjust the tension on the lever cap screw so that you can raise and lower the blade assembly with the lever cap clamped down. That is, the lever cap should allow movement of the blade assembly as you turn the depth adjust wheel. If it won't, loosen the lever cap screw until it will. But it is the engagement of the tang in the chipbreaker that makes the blade assembly move.
Wiley
