200+ woodworking book reviews
File types
File types
File types
Wayne Carson "TX"
>What is ment by the cut such as 2nd cut as apposed to other cuts
Re: File types
good question
Bill Tindall, E.TN
>Forest Addy hangs out on the main Forum and he is a machinist. I asked him to decode file nomenclature just this week. Post the question over there and may he would be motivated to write something up.
Re: File types
Re: File types *LINK*
Peter Evans
>The "cuts" relate to how aggressive, or not, the file is. The range used to be, something like (different companies and places used a variation on this name theme). Also remember that bastardry varies between makers, ie there are no external standards attached to these terms; also there is no guarantee that makers are consistent over time, especially with offshore manufacture these days:
Rough or Coarse
Bastard *
2nd cut or regular *
Smooth *
Dead Smooth
Extra Smooth or Fine
Those marked * are all that is made today in the American Pattern so called [originally English design].
There is an excellent summary of types of files (flat, hand, taper etc) on Woodnet written by the one and only Slav Jelesijevich.
Remember that coarseness also relates to length; so for example a 6" bastard is _roughly_ equivalent to an 8" or 10" 2nd cut.
In The Starrett Book for Machinists� Apprentices, 1917 p43 is an equivalence table between grits and files that is quite interesting.
GRADES OF EMERY
The numbers representing the grades of emery run from 8 to 100 (for example, No. 100 means the particles pass through a sieve with 100 meshes to the linear inch, i.e. the CAMI system for coarser grits � ed), and the degree of smoothness of surface they leave may be compared to that left by files as follows:
mesh 6�10 represent the cut of a wood rasp
16�20 coarse rough file
24�30 an ordinary rough file
36�40 a bastard file
46�60 a second cut file
70�80 a smooth file
90�100 a superfine file
120F and FF a dead smooth file
Swiss Pattern is another thing entirely, with the cuts ranging from 0000 to 8. The approximate equivalents are:
Swiss Pattern | American approx equivalent
0000
000 | Extra coarse
00 | Bastard
0 | Second cut
1
2 | Smooth
3
4 | Extremely Fine
5
6
7
8
These days only some of the Swiss cuts are available, something like 00, 2, 4, 6. Swiss files are higher quality for fine work, think Grobet as best known maker.
Then there are rasps, both machine and hand made.
Cheers
Peter in Sydney
File and rasp guide by Slav
Re: File types
Files is files -- not
Larry Williams
>It doesn't much matter what cut files have if the manufacturer doesn't properly prepare their blanks. Nicholson recently moved at least part of their production to Mexico and their quality took a dive. We use a lot of double extra slim taper files, we order them by the dozen. We just got our first from Mexico. Because irregularities telegraph into the teeth as the teeth are cut, I've always felt Nicholson could have done a better job of polishing their blanks before cutting the teeth. The Made in Mexico ones we got make the old Nicholson files look well polished. How can one expect to get a good finish with garbage like Cooper Tools/Nicholson is now peddling?
I'll avoid Nicholson files and probably everything made by Cooper Tools in the future.
Re: File types
Re: Files is files -- not
Denis Ch�nard, Orl�ans, Ont.
>Yikes, that's bad...
I had the good luck to stock up on a bunch of new old files and rasps last year (including some Grobet), I'm glad I did...
DC
Re: File types
Peter Evans
>Larry, know what you mean; a friend used a new N warding file once and it broke filing the mouth of a plane.
Luckily I have a lot of NOS taper files so am ok for quite some time I suspect. Also quite a few other old files (some from Slav on a US trip). I guess you are left with Bahco (made in Portugal), and how long before they go downhill?
Best of luck finding good files.
Cheers
Peter
Re: File types
Excelent info on link
Wayne Carson "TX"
>I noticed a link in the info says to send dull files to Boggs?? tried clicking on it nothing do they sharpen files??
Re: File types
Marv....... Northern California Lake Co.
>Larry,
Not that you are, but ve careful to not blame the Mexicans. It has everything to do with the parent company and how lousy a job they do training people and quality control. It's all about the bottom line and stockholders, at least in theory.
Do they lower their prices when they move our jobs to other countries? Usually not. It's all about the stockholders and greed. The best thing for us to do is to not buy their junk. Problem with that is, soon there will be nothing but junk and we'll still be paying 5 bucks or more for a double slim taper file that will wear out twice as fast. That computes to 10 bucks a file and people will still expect professional saw sharpeners to file a saw for only $15.00 and complain about it costing them too much.
Alan...I know, learn to file your own saws....*g*
Marv
Re: File types
Dave Burnard
>It's an obvious point, but anyone who is affected by such a change needs to let the manufacturer know they are no longer making an acceptable product. Voting with your wallet is one step, but making a stink about it in a way more visible to manufacturer is just as important.
Write or email the parent company and let them know personally that you will have to take your business elsewhere if they don't restore the quality of their product. It can't hurt.
Re: File types
Question on the 49 and 50
>They are still quality tools correct? Cooper has been making them for the past 10 years, according to Joel, so not all of there stuff is outsourced.
Stephen
Re: File types
I don't know, Stephen.
Larry Williams
>Mike Hancock is working with Michel Auriou to bring back Auriou rasps. I think I'll opt to do business with a company that cares about the quality of their tools. I'm done with Nicholson and will avoid anything from Cooper Tools in the future.
