Finish for outside bench
Wiley Horne -- So. Calif.
>Hi All,
I have an outside bench to make. Quarter sawn white oak. What's a good finish to make it last in the sun and rain?
Wiley
Re: Finish for outside bench
>First coat should be straight boiled linseed oil (BLO), applied liberally, allowed to soak in for a half an hour and wipe off all excess and allow to dry for 24 hours. Dispose of oily rags properly.
You can repeat this a time or two to make sure you have a good base, following the above proceedure.
Then you can apply a mixture of one third: BLO, Turpentine and McCloskeys Marine Spar Varnish (in the sheen of your choice), I usually rag this on. Please Dispose of oily rags properly. You can sand with 220 or go over it with a card scraper to remove any fuzz and repeat as needed.
Rub out with coarse linen cloth and it should last just fine. Depending on the exposure you may have to lightly sand and repeat the last one third, one third, one third mixture to renew, as needed.
Stephen
John Aniano in NJ...
>Wiley,
A few years ago (8?, 10?) there was an article in Fine Woodworking about this very subject - I think in the section at the end of the magazine about finishing.
I remember this because I made up the finish and used it on a natural finish cedar bench that sits outside. Also used it as a base coat under a painted cedar fence. The finish was comprised of a quality marine spar varnish, mineral spirits and paraffin wax shavings. The wax was dissolved in the mineral spirits and the spar varnish added later. This was brushed on liberally and when dry was topcoated with oil-primer and then painted. The exact proportions were in the article - perhaps someone with the searchable DVD can find the article.
Our bench does look a bit worn now and perhaps I should recoat it with the mixture - the fence still looks good.
Hope this helps,
John
BLO?
Larry Williams
>Boiled Linseed oil supports fungus growth. I was given this same advise about 25 years ago when I was building some white oak park benches for our local parks. I had ordered a preservative and it hadn't come in, while waiting and a deadline approaching the local paint guy suggested BLO. Before assembly I finished the first few benches starting with a seal coat of BLO followed by oil implement paint. The rest of the benches got the preservative then paint and this run also got stainless finish washers instead of the plated steel ones I used on the first benches.
A few years later the benches with the plated finish washers were rotting in place but the others were all fine. My house has three stories of wrap around porches. In my hurry to meet the first deadline I oiled the slats for the first run laying across the railings in each corner. As the first benches started to rot so did all the hand rails on my porches. I wasn't able to stop the fungal rot on the porch railing and all that railing had to be replaced.
Perhaps BLO would be okay in a dry place like Utah but I wouldn't used it in a climate that was even occasionally humid.
Lean over Fat
>The BLO should be the first coat followed by the others which will somewhat inhibit fungal growth.
The advantage of the straight BLO first is for the subsequent coats to better adhere to.
I would imagine adding any metalic dryer such as Japan dryer to BLO will reduce the microbial problem. I can think of a number of additional chemicals that will do the same thing.
Stephen
Paint
Todd Hughes
>I would just paint it with a good outside house paint.Matter of fact when I made my bench for my shop I painted it blue and am planing to do the same with the bench I am making for my new shop.
Not just benches but I see plenty of furniture that people make that I believe would be better painted then finished bright. Not only more traditional but more attractive I think. Don't know why more wood workers don't use a painted finish.......Todd
Re: Paint
>' Don't know why more wood workers don't use a painted finish.......Todd '
I couldn't agree more! I paint almost all my furniture. But all of the wood out here used by pioneers was pine and so they painted it and or grained it to resemble other woods, as was the Fashion of the World in the nineteenth century.
Stephen
Marv....... Northern California Lake Co.
>Wiley,
I suppose you are using white oak because you like the look of the wood and you want a clear finish to retain the look. Depending on the design of the bench, if you don't have tight joints where moisture can get trapped into them, BLO should work quite well. Your bench being out in the sun will eventually need some maintenance no matter what kind of clear finish you put over the BLO.
I think I'd be thinking in terms of what is commercially used to protect decks. But even a deck, no matter what you use will need periodic maintenance. Nothing will last forever thats why we have to repaint our houses. You might talk to people who build boats that are subjected to the worst kind of exposure to the elements.
Good luck,
Marv
Pedder Broockmann
>There's a lot of wood on boats, wich have to resist bad weather, so I would try "spar varnish" (if my babblefish is correct).
Cheers Pedder
I've had good luck with CWF... *LINK*
Scott Burr in Ben Lomond CA
>CWF (Clear Wood Finish) on Redwood. There seems to be a lot of redwood around here. 8^)
I put it on with a garden sprayer. Like any product used outdoors it needs to be reapplied now and again.
CWF @ Flood
Wendell @ Murphy, TX
>I used a product called Penofin Hardwood Formula on a mahogany outdoor bench. I like the oil based outdoor finishes rather than spar varnish. You're going to have reapply any outdoor finish eventually. The oil based typical can be re-coated without completely stripping the piece. With spar varnish, you'll have to remove the old stuff first before re-coating.
Wendell
Boat finish
Bill Tindall, E.TN
>The expensive stuff they use on boat wood indeed lasts in the sun. I used it on my window trim and it is holding up. Call a place that caters to boat people and they will have something or call Jamestown distributors. Nothing else I have tried holds up outdoors in TN.
>Thanks to all! Amazing number of approaches to take. It seems that all approaches are combinations of (1) a penetrating oil and spirits, and (2) a build coating of varnish or paint. And they all have to be renewed.
We get lots of leaf fall here, and driving wind-blown dust and debris when the Santa Ana winds blow. So on balance, I think the most cleanable surface is the one to go for. So am deliberating between spar varnish and paint.
Thanks again very much to all,
Wiley
>Wiley,
If you go with paint, perhaps something cheaper than white oak? Or do you just like working with oak? I like the smell.
Marv
Re: Lemme guess...
>Scott,
I would be giving that some very serious thought, but definitely not on the working surfaces.
Maybe finish the top with some good old bear grease. I'm sure I could get some from Stephen. Or was that lard? *g*
Marv
Opps...wrong thread....*smirk*
>Hi Marv,
Well, the oak I already have, which is one thing that commends it. But there's also some kinda gnarly looking hard white maple that would be good. Now you mention it, I do like sawing white oak--smells exactly like Jack Daniels whisky. Why would that be?
Now ya notice that Stephen recommended BLO, turpentine, and spar varnish. Didn't say anything about lard. Or whales.
Wiley
No but I have a recipe including lard & whales
>Just kidding!
If you paint prepare the wood the same way with blo and turpentine about 50/50 and let it dry thouroughly 48 hours. You might need to repeat the application on end grain, do this as it will help the paint from penetrating too deep in the endgrain, so you can get a better first paint coat.
Then after a light sanding it is ready for the oil base paint. It is the same folmula lean over fat, the blo/turps is fat and the oil paint is lean.
Stephen
