Clear finish that prevents wood darkening?
Paul Erickson
>I've just completed the inside walls (very crudely) of my shop with plywood, and would like to maintain the light color for the sake of light, but I would like to avoid painting, if possible. The finish I used on the floors is great in terms of durability, but typically the color has darkened significantly, even in the couple of months since I finished it. Does anyone know of a clear finish that will not darken the wood?
Thanks in advance.
cheers, Paul
Re: Clear finish that prevents wood darkening?
Dan Donaldson
>Many of the clea water based finishes will not significantly darken the wood, but it will darken on its own wiht time and exposure to light. There is really nothing that you can do to prevent that.
"RJ" Whelan
>Paul ... I seem to remember reading that some of the exterior oil finishes (for decks, etc) have UV inhibitors. You might want to check some of the manufacturer's web sites for more information.
A white "stain" might be just as easy to apply (with a roller) as a clear finish ... rj
If reflectivity is your aim...
>...you would do well to paint or stain the paneling to a bright value. Most woods either yellow or darken appreciably, regardless of finish.
Ellis Walentine, Host
Re: If reflectivity is your aim...
paul womack
Er. Most woods when exposed to sunlight *fade*, surely?
BugBear
Sgian Dubh
>Paul, I suppose it's my experience that most woods exposed to UV rays and air end up a sort of mid-brown given time. This suggests most pale woods darken, and most dark or richly coloured woods fade.
So, for example, 'pale' woods like the maples, European sycamore, ash, oaks, lime, birch, firs, pines, yew, pale fruitwoods, etc, yellow and/or darken to this mid brown, or thereabouts. Cherry does seem to do something a bit different going from a pale pinky, yellow brown to a dark red brown.
Walnuts, ebony; mahogany, the rich red ones anyway; padauk, kingwood, pomelle, teak, purpleheart, bubinga, brazilwood, etc, all quite strong or strikingly coloured timbers tend to fade, again to those mid-browns. Slainte.
