Re: Nicholson 50, 49, 48, 47.... ?
Peter Evans
>Scott, the Nicholson rasp range, at its peak was, as follows in increasing order of smoothness:
Wood Rasp - Smooth, Bastard [1/2 round, round, and flat] 6" to 16"
Cabinet Rasp - Smooth, 2nd cut [available in 1/2 round, and round] 6" to 14"
The above have no reference numbers.
Last makers (uncut edges), Pattern makers (cut edges) - 2nd cut, smooth
These rasps are basically the same except for the edge.
The numbers are:
Last makers cabinet rasps - 1, 3, 4, 6, 7, 9, 10 [8" to 10"]
Pattern makers cabinet rasps - 40, 41, 43, 44, 46, 47, 49, 50, 51, 52, 53 [6" to 12"]
Pattern makers 1/2 round rasps - 54 [8 3/4" x 1/2"], 55 [10" x 3/4"] 2nd cut. Unfortunately no illustration of this rasp, so do not know the shape of point.
The Gramercy rasp, to quote website "The shortest of the rasps is only 5" long (working length) and is inspired by the long-gone Nicholson 55 - except ours is hand cut." And at 25tpi would probably be categorised as smooth. I have one, very nice.
Note that cabinet rasps have a fairly flat arc (check your #50), 1/2 round is well more round. The shapes are pictured below.
The numbers relate to:
cut - 2nd or smooth
length - 6" to 12".
narrow or wide point [#49, #50 are narrow point]
There are also cabinet files and last makers files.
Trust that gives you enough to go on. Thanks to Gary Roberts for the catalogue info.
Cheers, Peter in Sydney
