Re: Bench Pictures for US
Roderick Drumgoole
>- What's the dimensions of the legs and are they solid or laminated?
5" x 3 1/2" (laminated)
30" length (including 2 1/2" tenons)
- Are you going the leave the underside open or fill it with shallow drawers?
Still thinking about the drawer option...probably not, as I would probably want it where one of the holdfast holes are located. I did, however make provisions for a sliding deadman by boring a slot under the edge along the length. My plan is to work the bench as is, and see if the sliding deadman will be something to add. Also, I did seriously consider installing a wagon vise (I think those rascals are neat) but after pondering, I didn't have the guts (skills) to pull it off - at least those were my thoughts. I will be adding some leather that I have just ordered to the vice.
-What type of glue did you use? How much? At least 3 gallons I bet.
One full gallon of Titebond (not sure if it was II or III), whatever the Big Box store had.
-I'd also like to see pics of the underside of the top as well.
I'll try! My digital photography skills are not where I would like. I'll try to show (don't know how successful I will be), that I did not spend much time on the bottom as there are still fore (jack) plane tracks that are clearly visible; however, it is relatively flat. I did, however concentrate on the areas where the leg tenons would meet the top and the area that has the groove for the sliding deadman - those areas were surfaced with the Try Plane. Without a doubt, the most important thing for me during the construction was to get major glue penetration on both sides of the laminations. So, there are still some visible glue lines under the top.
-Just as a matter of curiosity, how much $$$ do you have in this bench? Answer is optional of coarse. ;~)
Well let's see! The purpleheart came from eBay at a good price (the shipping of that heavy rascal was brutal, almost as much as the wood price). Total came to about $700 with the screws; if you include the niffty hand forge holdfasts add another $100. My first bench, which was all Poplar was about $325....it just depends on what type of wood you will use. I did price Maple as well...my cost would have approached the $1000 mark.
Based upon what I see I'd say that you have right at a foot of overhang on each end, am I correct?
Close! There is approximately 15" of overhang
Now, not to be a wet blanket, but does anybody feel that there is any danger of sag occurring over time?
I thought about that as well; if I were doing this bench again, I would seriously consider adding internal rods (maybe 3-4)for no other reason than to avoid what occurred to me during the final lamination with two big slabs - crown on one side and a cup on the other! This probably could have been prevented if I had the proper clamps and I had clamped the top with half of the clamps on top and half on the bottom. As for as sagging, Chris has a niffty chart in his book which refers to the "stiffness" of various woods; if you take a look, it show that Ash is quite 'stiff.'
you said that you long admired the Dominy bench, and I'd say that you've done a fine job of recreating it. To say that I am envious of this bench would be an understatement as I think it is a magnificent piece of workmanship and Craftsmanship.
Thanks....those words mean a lot to me being relatively new to woodworking coming from folks such as yourself and others on the forum who have many years under their belt.
Roderick
