Shop built Marking knives and awls
Dominic Greco in Richboro PA
>Hello Everyone,
Here are a couple marking knives and awls I made over the past week. The first one was made from some spalted Dogwood. It had some any holes that were filled with epoxy and coffee grounds. The ferrule is a 3/8" brass compression nut that was turned smooth. The "blade"is a section of HSS left over from a bunch I had purchased from ENCO last year (I made some 3 point turning tools). Since the wood was so "busy looking", I kept the shape simple.
After this success I decided to get fancy and cut up an old planer blade and formed (2) marking knife blades. I made a simple jig to work with my Veritas Grinder Tool Rest and ground the edge. Then I got fancy and honed and polished the faces so that they shone. I then used some ebony, and some bubinga scraps to make the handles. Like before, I used compression nuts as the ferrules.
It's pretty much the same story with the bubinga awl as with the dogwood one. Except I used a section of 3/16" HSS rod as the blade. I wanted something with a bit more heft, and a steeper angle to the point.
I admit, I went a bit over the top when it came to sanding. All were sanded to 15000 grit (micro mesh). I guess that's my old pen turning influence showing up again!
The finish is multiple coats of Watco's Danish Oil followed by a coat of Renaissance Wax.
Thanks for Viewing!
See ya around,
Dominic
