Oil for tools
Oil for tools
Oil for tools
Scott Burr in somewhat warn Ben Lomond, CA
>Hi All, I'm wondering what everyone here uses to oil brace pads and chucks, push drills, ya know all those little holes that say "oil"
Anyone try new lubercants like the teflon spray?
What's your favorite?
Re: Oil for tools
Lard
Re: Oil for tools
Jack Guzman from Maine
3-in-1
Re: Oil for tools
Made from Cats and Dogs
Re: Oil for tools
White lithium grease
Wiley Horne -- So. Calif.
>cause it stays where I spray it, doesn't harden but doesn't run either, and water doesn't get through it.
Wiley
Re: Oil for tools
White lithium grease?
>Hi Wiley, Spray in (or on) grease? That's new to me.
Re: Oil for tools
Boeshield T-9 on everything!
Alan DuBoff
>I prefer Boeshield T-9 is some of the best stuff, I use it on everything. This stuff can almost completely replace WD-40, which I keep away from all of my tools whenever possible as it gums up, eats plastics on wiring (for tailed tools), stinks, etc...
T-9 is also one of the best rust preventatives, but is not a rust remover specific, and Boeshield makes another product called Rust Free, that is one of my favorite rust removers, and actually is one of the very few products that smells good...not that Stephen's cat/dog lard doesn't smell good, but you'll have to ask him about that yourself.*g*
I keep 3-in-1 in my shop also, but don't use it very often as T-9 is my preference.
In a pinch, I've tried to use good 'ol spit, but it doesn't work very well at all...but it gives some satisfaction in spittin' on an old rusty tool...:-/
Re: Oil for tools
Should I just wrap a piece of bacon...
>Around it? Please elaborate! I'd like to keep the wild animals off my tools and lard seems pretty solid at most working temps.
Re: Oil for tools
Re: White lithium grease?
>Scott,
Go to the local hardware and find their giant shelf o' greases. The lithium grease comes in a pressurized can about the size of a can of WD-40, and like WD-40 it's got one of those skinny red tubes taped to it. Well, it'll shoot a stream of grease out that skinny red tube and right into the oil hole on a Yankee brace, f'r example. Spin that brace head or chuck and get a silly grin on face cause it don't stop for a while.
Wiley
Re: Oil for tools
Working temperature
>So what do you think the working temperature of friction tools that need lubrication is?
Do you want the lubricant to run out at room temperature? Don't use the lean parts of the bacon.
Synthetic and inorganic oil are not good for wood.
Stephen
Re: Oil for tools
Zoom Spout oil
Todd O. Cronkhite Maine Native, Presently Away
>I leaned about this oil while in HVAC class. Seems to be the choice for small electric motors. I like it, and I like the long spout flexible that stows inside the bottle itself as it allows me to get the oil where I want it. I get it at Ace Hardware.
T.O.
Re: Oil for tools
Various
Bill Houghton, Sebastopol, CA, gloriously sunny
>I tend to use what's left over from car lubrication: non-detergent 30W, auto tranny oil, marvel mystery oil (my favorite, because it smells best).
Re: Oil for tools
ThomD
>I get it from bike stores, it's the stuff I repack my hubs with, if it stands up to a thousand miles of me and my gear and isn't really run in, it should be good for what you need it for. The stuff I get is tootpaste like in a tube. Get some Phil's tenacious oil while you are there. Sticky oil, now there's a treat.
Re: Oil for tools
Re: Oil for tools
ThomD
>I always stay away from silicon and teflon, except when I can't. In some cases they are the metalhead equivalent of Pledge: an all purpose thing that does more harm than good. Now that I am into the old machine tools, I am really becoming aware of what is what in oil. Some of these old machines ran for 80 years on plain bearings and worked through the war 24 hours a day 2 shifts, and they are still good today. Takes 4 special oils to do it, and some of them are pretty much unavailable today. Moral is check the oil they really need first, as you are doing.
Re: Oil for tools
Have used this also, but it's messy to clean up!
Alan DuBoff
Re: Oil for tools
gun oil
Bill Tindall, E.TN
>The little holes that say "oil" seem to me to require oil, not a solid lubricant. Any light oil will do- 3 in 1, gun, trumpet valve, etc.
Re: Oil for tools
Re: Various
Kevin French, Antrim, NH
>Let's not forget the benefit of powdered graphite. I also mix it with a solvent and keep it in a squeeze bottle.
Re: Oil for tools
Re: Hi Kevin, what do you use it for?
>I use the solution to lube open tools like the shaft of my Yankee screwdrivers, vise screws, plane adjustment screws, great in locks and door lock sets. The solvent evaporate and leaves a nice film of dry lube and doesn't attract dust.
Re: Oil for tools
Re: Oil for tools
Whale Oil is usually liquid
Re: Oil for tools
So?
Re: Oil for tools
I've eaten it, and like "the other red meat!" :-/
Alan DuBoff
