Speaking of Nuts
>A couple of recent posts have got me thinking. First about saw nuts then about bench vice nuts.
When I first took up woodworking I made a bench out of laminated 2 by 4's with a metal face vice. I then found a nice old wooden vice screw and nut, so I decided to make a tail vice. I made a face plate with a garter to move the plate with the screw and secured the nut to the underside of the bench with hide glue. I was so proud.
Then my teacher/mentor/first father-in-law came over and saw the bench. Now he is an architect, blacksmith, cabinetmaker, printer, a real Renaissance man, got me interested in all of this. He just said 'why did you fix the nut?' and I said so the vice would work. He then pointed out that I should make a plate to attach to the end of the bench, the same size as the vice front plate with a hole for the bolt. The nut is loose and because it is rectangular it will ride on the underside of the bench.
I asked why? And he said so you could clamp angled stuff. I disassembled the vice, did as he said and had a fine usable vice. I have seen this on some other benches and have incorporated in bench vices I have built.
Just thought I would pass that story along. He also gave me an autographed copy of Eric Sloans A Reverence for Wood, which I got good money when I sold it, alas.
Stephen
