Name this saw
Name this saw
Name this saw
David Miller from Iowa
>Picked this up for a song yesterday. I love these one piece hollow cast iron handles - those foundrymen were true craftsmen.
Question - who made this saw? Is it European? There is a neat gizmo on the left end that pulls open, turns at a 90 degree angle to provide a lever to twist a screw to pull tension on the blade. I would guess at least the gizmo is patented.
Thanks
Re: Name this saw
Re: Name this saw
steve mackay
>Don't know but sure is pretty ! Can't be something made FOR Starret maybe ?
Re: Name this saw
Neat!
Tony Sade (Charleston, WV)
>Can you get blades for it? Do you plan to use it or hang it on a wall somewhere. Verrry interesting.
Tony
Re: Name this saw
I think you should name the saw...
>after yourself. Very nice cast iron hack saw. You should fit up a blade to allow you to use it. How big is it by the way?
Nineteenth Century is my best guess. Country of origin ?
Stephen
Re: Name this saw
Re: I think you should name the saw...
>I just put a standard 9"hacksaw blade on it and it fits fine
Re: Name this saw
Re: Name this saw *LINK*
Don McConnell
>David,
I can't be quite sure, but I think that your hack saw may be based on U.S.P.N. 2,221,231, issued to Fred A. Cassidy, of Pueblo CO, on November 12, 1940. I'm including a link to the relevant page of the DATAMP data base, from which you can directly access the USPTO (for which you'll need a TIFF reader) or Google images for that patent. By comparing the patent illustrations and text with your hack saw, you should be able to determine if your saw is based on it.
Hope this helps.
Don McConnell
Eureka Springs, AR
Cassidy hack saw patent
Re: Name this saw
Thanks Don
>1940 patent, wow. I would have guessed 19th century based upon the casting detail. It defintely looks like the right patent though, thanks.
