Question for wooden handscrew clamp fans *LINK*
wilbur
>I have a bunch of 12" wooden clamps that I really like, and would like to get some in a smaller size. Problem is, which size to get.
Any suggestions as to which size you find most useful?
Wooden handscrew clamp sizes
Re: Question for wooden handscrew clamp fans *LINK*
Glenn Madsen, near San Francisco
>I have a 6" Jorgy that I like and use regularly. Haven't tried larger ones, though. Smaller than that, I use little Garrett Wade sourced German aluminum/steel F clamps.
What are you building, size wise? That would influence what size clamps you need. I have, for example, a large pile of Bessey parallel jaw clamps in kitchen cabinet sizes, because that's where the projects were for several years.
I like the little ones... *LINK*
Scott Burr in Ben Lomond CA
>I use the 2" and 4" clamping area (capacity) ones quite a bit. I also use the largerones as well.
I have Jorgies, they very nice and very expensive. I also have some from Grizzly tools. The screws aren't as nice as the Jorgies but they work just as well. You can get 2-3 Grizzly ones for the cost of 1 Jorgie. Also you can make your own too!
Hand screws & kits
At Least a half a dozen of each size
Wait a Minute!
>Wilbur,
After thinking about it for a while, why don't you buy a set of wooden thread cutting tap and die in 3/4" and make all you need and want. The sets are relatively inexpensive, fun to use for clamps and other projects.
The sets are available from many sources and are all from the same place, not from around here. They need to be tuned up a bit, the v-cutter needs to be honed and properly set and the taps need to be de-burred.
For a nominal investment you can make all the clamps you need and the wooden threaded clamps won't PINCH you like the metal and wood ones do.
Stephen
fer instance? *LINK*
Tom Sontag - St. Louis
>Is the Beall wood threader the kind of thing you mean Stephen? You say that this one and most/all others are made by.... whom? Who else sells them?
Beall Wood Threader
No... *LINK*
>I was thinking of the traditional ones.
Stephen
Traditional Thread Die Box & Tap
Jim DeLaney, Austintown, Ohio
Rocklers has the 10" on sale *LINK*
>The current Rocklers ad has the 10" clamps on sale - two for $9.98
Jim D.
Rockler Clamps
Re: Those are the generics...
>and I suppose they are all right. But clamps like these, well built, will last for many decades, and saving $5 to buy a no-name seems like false economy. I wasn't impressed with these at the Rockler store. YMMV.
Re: Wait a Minute!
paul womack
But you lose the helpful ability of the Jorgy design to hold (extremely...) tapered objects.
BugBear
