Odd Stanley Block Plane 5 of 5
charle belden
>Underside of lever cap/chip breaker/palm handle. Not the "B" in the casting.
Any ideas of what this thing is and when it was last made?
Re: Odd Stanley Block Plane 5 of 5
Re: Odd Stanley Block Plane 5 of 5 *LINK*
Roy Anderson
>First, I can see you're wide awake in the middle of the night, like me. Second, this looks like it might be a #18. Check out the link and see how close it matches.
http://www.supertool.com/StanleyBG/stan3.htm
Jack Guzman from Maine
>I'm pretty sure Todd has it pegged. He knows his antiques. Clean it up and put it to use. My 18 and 65 stanleys are my most used tools. It's just one of the best made block planes ever.---Jack
charlie belden
>Found Blood Guts and Gore - again - after I did the original post. Looks like either a #18 or #19 - probably #18. BUT - the lever cap only has STANLEY stamped in it, no patent date, though the "spoon handle" is a forked type.
The forked type spoon handle is in the Stanley 1902 catalog but the illustration doesn't show the area of the lever cap where the patent date is stampled.
The whole lever cap/spoon handle mechanism was redesigned to eliminate the fork, which apparently was proned to breaking, probably when used by Tighter Is Better So Really Really Tight Must Be Best folks.
Surprisingly, the adjustable throat mechanism still slides without need of a persuader.
The "B" cast in the underside of the Spoon Handle indicates that it was cast by one of two foundaries Stanley farmed casting out to - and the "B" castings were done between 1899 and 1902, which jives with the 1902 Stanley Catalogue. BUT - Stanley was known to Mix and Match - using leftover parts from earlier models.
The other odd thing about this plane is that the adjustment wheel appears to be steel, not brass.
Still need to measure this thing - and weight it. Maybe that info will narrow the date down.
Anyone have any more suggestions as to when this thing was made?
