Lapping plane soles
Lapping plane soles
Lapping plane soles
Martin
>I am looking for assistance with lapping the soles of metal bodied planes. I am using silicon carbide grit (I got tired of spraying sandpapr with adhesive and waiting for it to set)on plate glass coverd with laminate. I know it takes a "long time" but how long is long for an 18 inch sole? Do you replace the grit after some time, and if so when? Do you replace the laminate as well or only when it becomes damaged? Any help would be appreciated.
Martin
Re: Lapping plane soles
Depends
David Miller from Iowa
>Upon how big the plane and how much you need to take off. You will find other opinions here, but I believe that once you get the mouth area flat you are fine. Take a magic marker and make scribbles on the sole and when you get a decent area cleaned off in front and behind the mouth (and obviously spots on the toe and heel), that is good enough. 20 minutes was the longest time I ever lapped a sole (a big #8 jointer with a twist) - usually about 5 minutes.
With regard to grit, I usually go by the sound. When the grit is new you can really hear it cut, then the sound tapers off after a minute or so and then I replenish.
Good luck.
Is the sole concave?
Wiley Horne -- So. Calif.
>Martin,
Very likely you've already done this....but just in case.... Please examine the scratch marks that are already on the plane's sole. What do you see? Where are the scratches, and where are the untouched areas? Reason I ask, is that you want to make sure that the sole is concave when you start out. If it is flat or convex, lapping won't work and may make things worse.
Wiley
Re: My web page on this  *LINK*
paul womack
sole flattening
Re: Is the sole concave?
Martin
>The 18 inch sole has consistant scratches on about 14 1/2 inches, with about 1 1/2 inches at the toe and 2 inches at the heel not being lapped. The central portion is consistantly scratched front to back and side to side.
Martin
>Martin,
Well, the good news is that you've got the mouth sitting down hard on the work. Which means the plane should work; you just don't have the flattening benefit of the full plane length yet. You could use a cambered blade in this plane, and let it be a fore plane right now, which would be very useful to you if you work from roughsawn lumber.
Two suggestions....One, before lapping anymore, quantify the shape of the sole as it stands right now. Meaning, set the plane down on a flat place, and find out how high in the air the unlapped portions are sitting. If you don't have feeler gauges, you can still do this to a pretty good approximation. For example, many scraps of paper that you have near to hand are about 4 thou thick (0.004"). A sticky note for example, or a page of your electrical bill, or a piece of bond out of your printer hopper. See how many thicknesses of paper will slide under the toe and heel of the plane at various places. You can figure out how much metal will have to be removed to make another 1/2", 1", 2", or 3" coplanar with what you've already done.
At that point, go to Bugbear's site (see just below) and see what's involved. If you keep lapping, even if the scratches spread out, the plane will be rocking slightly, and you're likely to be developing a slightly convex bottom. Bugbear goes into the more controlled methods of metal removal which will allow you to make the sole as flat as you want it.
Wiley
