Uses of edge-trimming block plane *LINK*
Bill Houghton, Sebastopol, CA, rainin' again
>Working on my fantasy buy list...
If I'm not building canoes or such, what are the peculiar uses of the edge-trimming block plane (as in the link) that make it worth buying?
These
Re: Uses of edge-trimming block plane *LINK*
Denis Ch�nard, Orl�ans, Ont.
>These are sweet planes, and while they're not essential I'm glad I have one.
They're long enough to joint short boards, say for making boxes. They can also be used to square the edges of longer boards, convenient if your jointer is set up with a straight blade, if it is set just a hair off square (easy to do) repeated passes with the jointer will get the edge more and more out of square. The edge-trimming plane is easy to set up for square, and will stay square once set up. It's nice to have a plane that you know will put a square edge on a board without fuss when you need it...
Just pick the A2 blade instead of the O1, I'm used to A2 but bought my edge-trimming plane with the O1 blade just to see the difference. Planes very nicely, but just doesn't last as long as what I'm used to (and I prefer to sharpen as little as possible, call me lazy :-)
DC
>Hi Bill
It is easier to explain by first saying what these planes are not ..
They are not a substitute for a jointer as they are too short to ensure a flat edge. The edge block plane is designed to create a square edge.
Further, it is not a plane I turn to when the boards are wide enough for a jointer, or short enough to fit on a shooting board.
However, when boards are thin (< 3/8"), where it is difficult to balance a wide plane, or the sides are too long for the shooting board, then it is a very useful plane. I use these surprisingly quite often when making boxes.
I used the following example a little while ago on WoodNet, where the same question was raised. I apologise to those who have seen it before..
My workshop, along with most of my tools, was packed up for an addition to home. This included the edge planes. I could have used them as I worked to smooth and level the rims of a box I was making. It had been cut open and the picture below was taken as I worked on it with the longest plane I had to hand. An edge plane would have been a natural for this task.
You can get along very well without one of these planes. You could instead just use an ordinary block plane. But they will get frequent use if you do have one (or two) in your arsenal.
