Return to service . . .
steve mackay
>Broken nose re-shaped, entirely stripped and re-japaned, polished and waxed up. Shaves cross grain just like new, baby ! Good look'n makes it even more fun to use. Yes, yes, just feel'n pleased with myself.
steve mackay
Re: Return to service . . .
steve mackay
>Putting everything back together I noticed the little doo-dad with screw that sites in the little inset is, actualy, got a beveled edge. Hmmmmmmmmmmmm, is this the " nicker " ? Cleans out the length-wise corners of the rabbet ?
>Nice clean job on the nose of that plane. If I didn't know the original was shaped differently, I couldn't tell.
Very nice Stevo... -Mike
Michael Stadulis in Southern NJ
Re: Yes, the cloverleaf thing is the nicker
Dave Mount
289 doesn't use the cloverleaf thing
Don in Northern Arizona
>It uses nickers similar to a #10 1/4, and there are two of them. They are almost impossible to find if you are missing one. If you have the screw, Ron Hock can make them for you if you send him a measured drawing of what you want. I'm sure Jim Reed could too, and he probably has an original in his arsenal that he could copy.
Don
Nicker on the other side
Re: When would you use the nicker on the left?
Dave Mount
>Thanks for setting me straight Don -- I guess you can tell who actually has a 289 and who just wishes he did. . .
Your post compelled me to read up on the 289 in the B&G. Interestingly, Leach mentions that there was a brief period where the 289 did have the cloverleaf nicker (not that I knew that when I orginally answered).
Your picture has me wondering when one would use the left side nicker. Only time I can think of is if you were using it as a dado plane, but that seems unlikely at 1-3/4 or 1-7/8 wide. . .could it just be there as a spare?
Best,
Dave
Actually...
Scott Burr in Ben Lomond CA
>The late model 289's did use the "clover leaf shaped" nickers.
For Southpaws or...
>Planing left to right instead of right to left.
Nice!
>Well done Steve. Brought another one back to life eh!
>Dave,
You can flip both the fence and the depth stop around and use it left-handed. Pretty cool.
Don
Right you are, Scott
>I needed to check Blood and Gore again to see that mentioned. Steve's is the typical model, though, with the angled blade nickers.
Don
Re: How does a RH skew work LH?
Dave Mount
>I still don't get it. If you used it as a lefty, wouldn't the skew would push the plane out of the work? I thought the leading edge of the skew needed to be to the inside of a rabbet so that the slicing action kept the fence snug to the work. If the iron was straight across, I'd get it. But reversing a skewed plane?
Feeling stupid,
Dave
Nice! I am still waiting for the LV version...!
HC Sakman
Your right Dave...
>Not stupid at all...8^)
You will need to apply some sideways force to keep the plane up aginst the work when planing the "wrong" way so to speak.
