Matt, how Big is your tree?
>That will let us know what you are up against. If it is a small orchard cherry then you can simply buck, quarter and rive out small pieces. If however you have an old growth wild black cherry then you will need a few tools and they will be expensive.
As Adam said you will need a pit saw and someone to work the other end. The pitman is on the bottom and just pulls the saw down (you have gravity on your side), keeps their mouth shut and wear a big hat, actually the preferred job. The tiller man on top has to lift the saw back up and make sure the saw stays on the chalk line.
You will also need a barking spud to remove the bark, to prevent damage to the broad ax, scoring ax, adze and pit saw. You will need a two trestles about 8 feet off the ground or a pit (hence the name pit saw) that deep with a couple of large logs on each end to dog the logs to. You will also need ropes, pulleys, block and tackle, a cant hook and pivey for moving the log around, a pair of log dogs and a chalk line.
Remove the bark and snap four chalk lines to get the best size square timber, you only need to flatten off two sides, the other two are slabbed off, although you can square up the saw log. Now with the scoring ax, score every 10 inches or so in a V shape down to the chalk lines on the side of the log. It helps to use the log dogs, large iron staples, to secure the log as you are working it. After it is scored, then use the broad ax to remove the wood in between the V cuts. Use the adze to smooth off the surface of the top and bottom.
Next mark out the width of the boards on both ends of the log and snap chalk lines. Then use a plumb line to mark down to the flattened off bottom of the log and transfer the lines to the underside. Then wrestle the log onto the trestle or over the pit and dog it down to hold it in place. You will need to move it at least once and it is a good idea to cut all of the cuts as far as possible, usually up to the trestle or dog log until the log needs repositioning.
The log should protrude out the end of the trestle or pit dogging log and the cuts are made up until they are near the dog log. Then reposition the log so the kerf is on the other side, remove the box from the pit saw, insert the blade into the kerf, reattach the box and continue.
When you reach the other end it will require repositioning of the log so the kerf is on the outside of the dog log and continue. However you will notice that the tillerman will be walking backwards off the log, so this is when they reverse position and 'reverse the handle in the pit saw' to finish the cut.
Then dry the wood, nothing to it.
Good Luck
Stephen, who has actually cut boards out of a log using the above methods, I prefer the pit.
