Beeswax & mineral oil
>I like beeswax. Somehow I have ended up with a small collection of different cakes of beeswax. My favorite one was purchased at a craft show this summer, a nicely molded 1 pound cake I think I paid $5 for. I have been to several woodcentral gatherings where someone gave me a cake of beeswax. I have been reading about keeping bees lately, on the web and in books, and came across a simple recipe that said "mix beeswax and mineral oil to make a wax". I don't recall where I read it. It did not say how much mineral oil to put in the wax, or any other details. I had cut a large end grain cutting board into a number of small pieces about 6" x 8" because it had a crack in it. I thought they would be a handy size to ahve in the kitchen and Megan seemed thrilled. All they were missing for about two years was some sort of finish. The mineral oil and beeswax finish is perfectly safe to ingest; mineral oil is commonly used as a laxative and that is where we found it in the pharmacy. I shaved a small cake of beeswax with a grater, probably 4 ounces or so, into a pint jar. I had put about 1 finger of mineral oil in the pint jar to start with, and it seemed to just cover the wax when I was done. In the future I think I will shave the beeswax into the pint jar then pour in enough mineral oil to cover it. We thought perhaps the beeswax would disssolve in the mineral oil. It does kind of get soft after a day or two but does not actually dissolve well. I thought the next thing to try would be melting the wax in a double boiler. We put some water into the bottom and top sections of a double boiler and set the pint jar with the wax and mineral oil in the top of the double boiler and turned on a medium heat. It took a little while for the wax to get hot enough to melt, but it was clearly completely melted at one point; there was no mistaking that the wax was melted. I stirred it with a plastic spoon. I thought perhaps the wax would seperate from the mineral oil as it cooled but I just set the pint jar on the counter and let it cool. Once it cooled I had a creamy white wax mixture about the consistency of cold butter and the wax and oil seemed to be combined well. I scooped out a little bit with the plastic spoon and waxed several cutting boards last night. It makes a very nice wax which I plan on using when I make some wooden spoons for a craft show this spring and for cutting boards etc.. I have an old wooden rabbet plane that I think I will clean up with some simple green and then put some of this wax on as a finish.
Re: Beeswax & mineral oil
Edward in Vancouver
>So That's the secret recipie!
For years now I've been using "Claphams Salad bowl wax" on my maple topped baker's tables. I like the stuff, smells nice, protects the wood well, has the consistancy of shoe polish, but at $15 for a can, gets a bit pricey. Guess I'll be making my own when the can gets used up......
>If you want to avoid the slippery slope of mineral oil, you might try walnut oil as a finish on cutting boards. Unlike mineral oil which never dries, walnut oil is a polymerizing oil and will dry.
It is also a lot tastier than mineral oil when mixed with a nice balsamic vinegar.
Stephen
Walnut Oil
tek-Brunswick, Ohio
>Mike Mahoney is a well known woodturner. He makes and sells salad bowls as him main product. He sells Walnut Oil that is heat treated to dry faster. He also sells an oil wax mix. I think Woodcraft and Rocklers both carry his products. You could make your own mix of beeswax and walnut oil if you wanted to. Walnut oil does take a long time to dry, but mineral oil never does. Both oils are safe for food contact. Mike also does a lot of other turning work. Some of his work is quite complicated, but salad bowls got him started.
