grits
Dan Collins
>I am a recent convert to using sandpaper to sharpen chisels and plane blades. Acually I'm not a total convert because I use the sandpaper up to 1000 grit, then I often make a few passes on a 6000 grit Norton waterstone, then a final swipe or two on a leather strop. Although I have no microscopic comparisons, the blades often feel sharper after using the 1000 grit sandpaper than they do after using the 6000 grit waterstone. Does anyone know if the "grits" measurement is the same for sandpaper as it is for a waterstone, i.e., is a 1000 grit piece of sandpaper the same as a 1000 grit waterstone? I use a fixed honing guide. My waterstones are flat and I put the sandpaper on a flat piece of marble, so all things being equal, I would think that the 6000 grit waterstone would yield a much sharper blade than a 1000 grit piece of sandpaper, but at least according to my fingernail test, the 1000 grit sandpaper usually feels sharper. Any idea why?
