screwdriver query
screwdriver query
screwdriver query
Bill Tindall, E.TN
>What do you all use for #4-#2 brass screws. I don't own anything that makes a good fit for these little screws.
Re: screwdriver query
Phillips or Robertson?
Denis Ch�nard, Orl�ans, Ont.
>In either case a #0 should do the job, maybe #1 on the #4 screws.
DC
Rob Brophy
>I use a #0 (yellow) Robertson screwdriver with an inset carbide(?) tip...the square recess driver doesn't lose traction on the wee screws like phillips and slot drivers.
Lee Valley has a great deal on genuine Robertson bits right now. NFI just an occasional customer.
>Bill,
While I seldom use brass screws that small because brass screws were used only on compass and other applications where ferrous metals mattered, in the nineteenth century, I do use them small iron screws.
I have a couple of old jewelers or watchmakers screwdrivers that work quite well.
I have a couple of small screwdrivers I have made from saw blades for very fine slotted old screws.
I have a large number of screwdrivers and always buy more old ones as it is extremely important to have a proper fitting screwdriver. They are all properly 'sharpened'. I take the extra time to make sure the blade of the screwdriver fills the entire slot to prevent it from camming out.
The importance of a proper fitting screwdriver and its lack of proper use is demonstrated by all of the cammed out screws in existence.
Take care when snugging up brass screws it is easy to twist of their little heads. It is a good idea to lube up the screws, I have a grease dup under the end of my bench qne I dip nails and screws in the beeswax/tallow mixture.
Stephen
Screw chart *LINK*
Wiley Horne
>Bill,
Someone posted the attached chart on a forum the other day. It pulls everything together. Look down at the bottom for driver sizes. Short answer: No. 1 Phillips if it's a Phillips head.
Main thing I ever learned about these things--predrive the hole with a steel screw of the same size, and then use beeswax on the brass screw.
Wiley
Screw Chart
think traditional
Bill Tindall, E.TN
>I only use slotted brass screws for hardware installation. Now on a sheep pen its square drives for sure.
clarification...Adam Help!
Bill Tindall, E.TN
>If I needed a screw driver for a #10 screw I would go buy a Klein and be assured that I was getting the best screwdriver for the task at hand. As far as I know Klein does not deal with #2 screws. I don't think any local source of screw drivers deals with #2 screws, or #3 or likely #4. I have jewelers screwdrivers in sizes down to micro for machine screws but they are not suitable for driving wood screws-insufficient torque on their tiny handles.
Surely someone here installs small brass hinges and prefers the look of a slotted screw in this hardware. Specifically, what is a source for a quality new screwdriver that will do #2 to #4 slotted screws?
Re: clarification...Adam Help!
Hunter
>I have a stash of 25-cent yard sale screwdrivers that i keep just for this purpose. Most are 50 yr old plus american made with wood handles. When i need a screwdriver to fit a specific screw, if i dont have one that fits it right, I just take an old one and grind it to fit. Obviously this works for slotted ones.... guess you could grind your own phillips but would be a lot more complicated!
A source for new drivers to fit smaller screws might be a local electrical supply house, there are a lot of small screws in electrical assemblies. You could always get a smaller sized screw driver and if the handle is too small you could remove it and make a new handle that is easier to grasp.
Paul in NJ
>My local Sears Hardware store has a nice selection of smaller screwdrivers. Myself, I would rather re-grind a spare screwdriver rather than making a special trip to buy one.
Paul
Bruce, a MN Galoot
>The only source I can think of, Bill, is a good gunmaker/repair guy. They deal with pretty small screws and their screwdrivers seem to be on a par with Klein.
Bruce
Question on regrind
Dan Donaldson
>What is the proper geometry for a slotted screwdriver tip so that it seats properly in the screw and does not cam out?
Jack Guzman from Maine
snap-on
>If you can,snag a snap-on dealer next time you see one parked at a garage.Snap-on sells some tiny slotted drivers and they are good quality,also guaranteed for life.---Jack
there is a suggestion I can use!
Bill Tindall, E.TN
>There is a Snap on Factory near by.
How?
Bill Tindall, E.TN
>while I have been successful in grinding relatively wide pane irons and chisels I have been less so with narrow screwdrivers. I have problems keeping the end square and uniform. Do you have any tricks to make this task easier or more reliable?
Also, is it true that the slot in machine screws is a different profile than wood screws?
Re: Question on regrind
>Dan,
Initially the screwdriver blade should seat on the bottom of the slot and touch the top sides of the screw. It needs to be wide enough to engage the entire slot and thick enough to fill the entire slot. With counter sunk bits, the blade is not as wide as the slot. If it is as wide as the slot it will damage the wood of the countersink.
On Pan head screws the geometry is the same but the blade is always as wide as the slot and as thick.
Some old hand cut slots on old screws may be at angles and some are very thin requiring a very fine blade screwdriver.
Now on old screws, those that have been used at least once, the geometry changes in that the slot is now probably wider or cammed out. Fit the widest blade as possible into the old slot, push down while turning helps prevent the blade from camming out.
Old screwdrivers are usually flat or have a flat place for a wrench. This should be used on old screws as it gives more torque and allows more pressure to be pushed down on the handle.
Hope that helps.
Stephen
Re: How?
Bob Hackett
>it`s been my understanding that the slots of both wood screws and machine screws are the same profile.
It`s also been my understanding that the best way to prevent cam-out is to grind the blade of a screwdriver with a slight hollow grind to allow the end of the blade to contact and grip the bottom of the slot first.
Another old trick to prevent cam-out is to put a dab of valve grinding compound on the blade of the screwdriver.I suppose for folks like you Bill,diamond paste will do the job too.;^)
Mainely,Bob
