How was squareness determined in 1750?
Bill Tindall, E.TN
>The date is arbitrary. Did they have squares back then or was there some other clever way they determined the end of a board was square, or marked a board for sawing square? If they had squares, how were they made? There have been reports of making all sorts of tools on this forum but I don't recall anyone ever showing square making.
Re: How was squareness determined in 1750?
Dan Donaldson
>I think that I read somewhere that they used 3-4-5 to generate a right angle.
Marv
>Hi Bill,
It's quite easy to make a square so it is square. After you make it, you merely check the squarness by turning the square over and checking against the line made from the first check. If both lines line up, the square is square. Once you have a perfectly squared line, you then can make future squares to that line or a stop to square to.
Marv
Jeff S.
>And.... be sure to do this outside to outside, inside to inside, outside to inside and inside to outside. If the blade and handle sides are very parallel, it can be tested with any one of the above.
Dean J in MN
>Adam did a square making article PWW Aug 2006.
Here is one I made using that article.
By using a square made in 1740
Marv
>Jeff,
It couldn't be a matter of the handle and blade being parallel, that would have to be a sure thing before attaching them to each other.
Marv
Jeff S.
>I am not sure that I am following you, Marv.
I meant to say that if the blade sides are parallel to one another, and the handle sides are parallel to one another, and it is assembles such that any of the various combinations is square, then the rest of the combinations will be square.
Jeff S.
>Sorry for the typo's.
It should read,
"I meant to say that if the blade sides are parallel to one another, and the handle sides are parallel to one another, and if it is assembled such that any of the various combinations is square, then the rest of the combinations will be square."
Notes from Moxon
Wiley Horne
>Jeff,
Moxon agrees with you about the importance of the sides of the blade and stock being parallel. He calls these pieces the 'tongue' and 'handle' respectively. He emphasizes the point about parallelism, and later describes a situation where you would rely on the inside square, and then another situation where you rely on the outside square.
Interestingly (to me), Moxon says nothing about how the right angle is to be achieved. However, he does point out that, once the tongue gets ragged from the 'pricker' (striking knife), the mechanic would plane it true again. Well, if you can plane it true after it gets chewed up, I would speculate that's how they might true it to begin with. Using what reference? I have to think it would be another square (Stephen) or the 'double the error' technique (per Marv and yourself).
But Moxon doesn't answer Bill Tindall's original question.
Wiley
Geometry?
George Bustamante
>Simple geometry problem - bisect a line using a compass, dividers or similar tool and the four points determine two lines that are perpendicular. The greater the separation of the points, the more accurate the perpendicular angle (squareness).
The ancient greeks and others had this figure out long before Moxon...
elaborate please
Bill Tindall, E.TN
>How would one do this operation to determine , or mark for sawing, squareness on a board end?
Jack Guzman from Maine
500 bc possibly 2500 BC
>I did a little research. It seems that Pythagoras who is credited with the theory that makes it possible to create a right triangle lived in the 500s BC. However some experts believe that Egypt had already been using a similar theory in the construction of "megalithic monuments" around 2500 BC. So,my point is,I'm sure that in the 1700s they had the knowledge to create a square.Of course that doesn't really answer the question. What did they use?My guess is that they had a square object on hand,like we use a try square.---Jack
Re: Another method to square a board
Marv
>Bill,
I can't be sure how it was done during the 1700,s or even before that, but here's how I would square a board if I didn't have a square.
First saw the board as square as you can by just eye-balling it. Then flip the board over onto itself so the two cut ends can be compared. The amount that the board is out of square will be compounded. Somewhere between the two out of square ends you will find where square is by splitting the differences, then make one more cut. Once that is established, you can use the squared board as a template for making square cuts on other boards.
Did they have levels in the 1700,s? You can square a board with a level by standing the board on end and making one edge plumb.
Marv
If your saw is shiny you don't need a square
Elaboration
George Bustamante
>Geometry gives you your reference to measure "squareness": two perpindicular lines. That established, you could build shooting boards, mitre boxes, bench hooks and of course, set your try square up to be super accurate.
The procedure for laying out a shooting board, for example, would be to lay out the datum edge, establish a parallel line to the edge, bisect that line, and then lay your batten (stop) edge along the perpendicular line.
You could also butt the datum edge of two boards to gether, and bisect the datum line giving you a line perpendicular to the edge.
