help me to understand importance of flatness
Bill Tindall, E.TN
>Why is bench/board flatness so important in planing thin stock? I would suppose the most common thin stock planed would be a drawer side, say 20" long. My planing board is an arbitrarily chosen piece of 3/4' plywood; whatever is at hand at the time of need. And I plane this side with a 12" long plane.
Case 1 Planing board ( or bench) is 0.010 high in the middle of this 20" length. I would presume the plane would follow the hump more or less. So, I suppose that something between 0 and 0.010" more could be removed from the middle of this drawer side than from the ends. Actually I think I would tend to plane a taper, which would be untaperd when I reversed the piece to plane the other side.
Case 2. Planing board is 0.010 low in the middle. To some extent the plane is going to bridge over this hollow and the middle of the drawer will be between 0 and 0.010" thicker in the middle.
After assembly of the drawer it will be suspended over yet another board of some sort ( in my case another piece of plywood nearly the depth of the drawer and planed to yield about 1/32" clearance in the drawer opening. It is common for me to have to plane a few more shavings from the front, or rear, of a drawer during fitting, I suppose because the case is not perfect..
I can't see how substrate flatness, be it bench of board, will affect drawer construction or fitting.
Now I just finished a bunch of boxes and trays for Christmas presents whose board thickness is 5/16 to 3/8". These are dovetailed affairs. Again I don't, and didn't, see any impact of the flatness of my plywood piece clamped to a bench that assuredly is not flat.
Admittedly, if the lack of flatness was well beyond 0.010" I can see problems. In that case I select another piece of plywood.
