grinding a plane blade?
Charles Jackson III
>I am having trouble grinding a straight edge on my smooth plane blade, I have been using 100 22 grit sandpaper but it dont seem like its doing the job.I am about to give up.
Re: grinding a plane blade?
Denis Ch�nard, Orl�ans, Ont.
>Charles, you don't want a straight edge on a smooth plane blade, you'll end up leaving plane tracks on the wood. What you want is a slight camber (like 1/64" or even less), use a square to gauge your progress as you grind, then hone on the medium of your choice.
DC
Reference line
Bob Hackett
>The easiest way for me to grind any blade is to take a black magic marker and coat the face opposite the bevel(the one you look at while grinding),then scribe a reference line on that face.The line will show up real well thru the black and make it easy to grind to.
The marker will also change color due to heat so it will let you know the temp is climbing well before the steel turns blue.
Use a light touch and be patient.A 60 or 80 grit belt wouldn`t hurt either.
Mainely,Bob
A few questions
Scott Burr in Ben Lomond CA
>Are you using a sandpaper on a referance surface or a belt sander?
Are you using a jig? If so what kind?
